ERROR: Unexpected status of script: Drivers\Kinetis\TimerUnit_LDD.rgi, please contact Freescale support. bsp_twrk60d100m
2,521件の閲覧回数
yorknh
I have a clean, basic licensed, install of CW10.5 and MQX4.0.2 I also have a TWR-K60D100M module and tower kit that I am trying to run a lab that had been shown at the recent DwF conference in Boston. The first step of the lab is to drag the twrk60d100m.wsd into the project pane. That basically sets up the build components for MQX for the tower kit. Immediately after performing that step I get the following error:
DescriptionResourcePathLocationType
ERROR: Unexpected status of script: Drivers\Kinetis\TimerUnit_LDD.rgi, please contact Freescale support.bsp_twrk60d100mPWM
Processor Expert Problem
I saw a similar problem listed that said that the solution was to delete a directory under Users/All Users/Processor Expert. I tried deleting the entire Processor Expert directory but it didn't make any difference.
I am running Windows 7 Pro 64bit.
3 返答(返信)
1,981件の閲覧回数
vfilip
could you please post here the ProcessorExpert.pe file from you project in order to reproduce it on our side?
For now as workaround please close the "Configuration Registers" view, it should help to avoid this error report.
Vojtech Filip
Processor Expert Support Team
1,981件の閲覧回数
yorknh
Hmm, I don't think I had the "Configuration Registers" view open.
This morning when I started CW, the error is gone. I've attached the file you requested, nonetheless.
1,981件の閲覧回数
vfilip
I was able to reproduce it and I have classified it as a bug in latest version of PEx for CW. As workaround is necessary to close the "Configuration Registers" view. The fix of this issue will be published in update of CW V10.5 (Q4 2013).
Vojtech Filip
