Difference between NXP bootloader Examples
durgasivakrishn
I am using the NXP_Kinetis_Bootloader_2_0_0 for developing the custom bootloader for MK66FN2M0VLQ18. I found the two examples in the SDK, But not able to get the difference between them can anyone help me out the difference in the path of "NXP_Kinetis_Bootloader_2_0_0\targets\MK66F18\mdk" between flashloader and freedom_bootloader.
Thanks & Regards,
Sivakrishna
durgasivakrishn
Hi Daniel,
Thanks for your response, I would like to develop a custom bootloader could you share a general document to steps to be followed in the bootloader development.
Thanks & Regards,
sivakrishna
danielchen
Please refer to chapter 10. Kinetis bootloader porting from Kinetis Bootloader Reference Manual.
danielchen
Hi Sivakrishna:
The flashloader is a bootloader that executes from target RAM memory on the platform.
The freedom_bootloader is a bootloader that executes from target flash memory on the Freedom platform.
