Design secure Firmware that no one can flash and retrieve code in/from MCU.
1,391件の閲覧回数
rohitchudasama
Hello guys,
I want to design my firmware that no one can download hex file in my MCU (MKE18F512VLL16) and no one can retrieve my installed code from MCU.
Is it possible using ROM Boot loader ?
Anyone have idea about that than let me know.
Thanks.
ラベル(3)
1,264件の閲覧回数
JHinkle
Senior Contributor I
The short answer to your question is that you CAN have a bootloader that "secures" the chip so it can not be dumped - only bulk erased.
The longer reply is that you may have to put a lot of work into getting that into place.
The standard bootloaders available AND the process of updating your code via the bootloader may not make that easy to implement.
Good luck.
Joe
