DMAMUX MKV58
DMAMUX MKV58
jmasgiro
Can I configure DMAMUX with CH0 routed with source 16 (SPI0 Receive) and CH17 routed with source 16 (SPI1 Receive)? According to the KV58F2M0VLQ24 datasheet, on DMAMUX chapter, source 16 has a different peripheral associated with it depending on whether you use the 0-15 or 16-31 channels.
Pavel_Hernandez
Unfortunately, this is not possible, because the source is the same and only changes according to the output channel.
Pavel
jmasgiro
Dear Pavel_Hernandez,
thank you very much for your advice. The only solution I have is use SPI2 instead of SPI1.
Pavel_Hernandez
Let me review your information, when I have more details I will contact you.
Pavel
