Communication freedom-freedom
gerardocisneros
Hello! I'm trying to communicate two freedoms by UART but I have some troubles with the ports of UART. I can't receive data from ports with UART configuration.
Original Attachment has been moved to: FRDM.7z.zip
Kan_Li
would you please help to describe how to connect two freedoms together? by which UART? how about the hardware connection? It would be helpful to review the project you attached.
BTW, you mentioned " I can't receive data from ports with UART configuration. " How you receive the UART data? by a software such as HyperTerminal?
