Clear EnetTx buffer in FRDM-K64F board
529 次查看
maksim_lipskiy
Hello everybody!
Sometimes when working with the FRDM-K64F board, there is a situation when the transmit buffer may not be cleared "ENET_DRV_CleanupTxBuffDescrip(enetIfPtr);".
Flag enetIfPtr->bdContext.isTxBdFull  is always set.
How do I fix this error?
Thanks.
PS: Sorry form my English.
454 次查看
isaacavila
This flag is set as long as last packet is not sent (or ACKed on a TCP transmission). Stack (in your case, lwIP) should handle the logic to change TxPointers once these message are sent.
In other words, you should not clear this flag manually until lwIP defines if previous packet was sent correctly
What application are you using? Did you try to use a sniffer to check if data is sent/receive correctly?
Isaac
