Can someone advise the difference between LPUART and UART?
19,546件の閲覧回数
johnman
Is LPUART just low powered version of UART?
15,712件の閲覧回数
kerryzhou
Hello John Man,
      If you check the reference manual about the LPUART and UART, you will find the difference.
     LPUART is the low power UART, it can works in the low power mode, I post some information for your reference:
1.LPUART
2. Normally UART
Wish it helps you!
Kerry
