Can USB-KW24D512 USB work with the internal crystal (FEI mode)?
1,800 次查看
luwan
I am trying to enable USB on USB-KW24D512. Is the USB able to work with the internal clock (working at FEI mode)?
1,659 次查看
miduo
We really do not recommend to using the FLL to clock the USB module, that will led a non-working USB applications. The MCGFLLCLK does not meet the USB jitter specifications for certification.
1,659 次查看
luwan
I am now using PLL (PEE mode) and the USB CDC is able to shown as ACM0 (enumeration successfully).
But the board fails to tx/rx traffic, are there any guide lines to help for troubleshooting?
1,659 次查看
miduo
Please let me know the what board you are using? The customer board or the evaluation board?
