Hi All
I wanted to check the uVision operation with the freescale Tower boards via OSJTAG but couldn't select the OSJTAG debugger as instructed in the Keil tower kit user's guide: http://www.keil.com/freescale/mcbtwrk60_qs.pdf
Has anyone else been able to use it? I upgarded to uVision 4.22 to be sure that I have the latest version.
Mark
Solved! Go to Solution.
Hi All
Answering my own question: It is necessary to also install newest OSJTAG drivers -
http://www.keil.com/download/docs/408.asp
Then the OSJTAG appears in the list...
Mark
Hi All
Mark
