Bus Clock FRDM-KL25z
1,436 次查看
Lizeth
Hello
I want to know the defautl clock for plattaform clock, bus clock and system clock using the SDK for the FRDM-KL25z
1,414 次查看
victorjimenez
Hello Lizeth,
Every example from the SDK is different, hence every example uses different clocks at different frequencies. Looking at the MCUXpresso Clock Config tool inside the SDK examples is a good idea to understand how the clocks of an example are configured.
Victor
