A71CH with IBM watson
trialaccount12
Contributor V
hi,
   I followed this documentation https://www.nxp.com/docs/en/application-note/AN12186.pdf and established a connection between A71ch using FRDM K64F board and IBM Watson (Blue-mix account) .
             I ran the demo and it was working. When I tried to run the demo again , its not working. It is showing the logs that transaction has been made but no data is showing up in recent events and my device is showing a status of disconnected.  All i understand is, the connection has been established but the data is not coming up and i dont understand why y device(FRDM k64F with A71ch) is offline for no reason when it is connected to Watson platform.
Any leads would be highly helpful.
Thanks and Regards
Niranjan
trialaccount12
Contributor V
Edit1: I am able to see the data . But there is some connectivity issue between my device and IOT platform. ! Because of that I am not able to publish the data. How do I fix that?
