9 bit dma uart RS485
albertomainoni
Fresh Out Contributor
Please, how can I get and send ninth bit with DMA and UART?
Hui_Ma
It will be better to use software to set/read UARTx_C3 [T8] about 9-bit UART transmit/receive.
Even if using the DMA engineer, it also need core intervene to write/read the ninth data bit with UARTx_C3 [T8] bit.
Wish it helps.
Hui_Ma
Wish it helps.
