1N41K vs 2N03G/3N03G Masks
已解决
跳至解决方案
1,842 次查看
jackjamieson
What's the difference between the 1N41K, 2N03G and 3N03G Masks?
Specifically I'm interested in the difference between MK21FX512VMC12 and MK21FX512AVMC12. Can these be used interchangeably? If not, what changes are required to change from one to another?
Is this Engineering Bulletin applicable to all devices in the 1N41K, 2N03G and 3N03G Masks even though only the K22F 120 MHz devices are explicitly called out? Or is there a similar Engineering Bulletin available for the K21 parts?
https://www.nxp.com/docs/en/engineering-bulletin/EB811.pdf
标签 (1)
1 解答
1,819 次查看
Robin_Shen
Yes. But NDA required.
K21F Rev 1.x / K21F Rev 2.1 Differences 2N03G / 3N03G / 1N41K Mask Sets
I have share this file to you through NXP Case portal (Support Tickets).
在原帖中查看解决方案
1 回复
1,820 次查看
Robin_Shen
