Problem while launching a debug for openSDA for KL25Z128VLK4
8,291 次查看
bhupindersinghk
I am new to this board and KDS.
I was trying to execute a basic program to blink LED...
However while debugging the code through inbuilt openSDA a pop up windows shows as follows...
I have also tried re-installing the P&E drivers.But nothing seems to work.
Also I am certainly sure that I am following the bootloader updating process properly.
I have also tried installing KDS in different system however same error occurs. Even i have tried on different kl25z128vlk4 board but nothing works.
Please suggest any possible solution for this problem as soon as possible.
14 回复数
7,828 次查看
Hello ,
Which board do you use? FRDM-kl25? or your customer board ?
If the frdm-kl25, please drag the  file of "DEBUG-APP_Pemicro_v102.SDA" to the bootloader,
the plug in again the usb to  J7;
Then configure the debugger as this :
If still can not work , please take a screenshot about the process of your operate .
Alice
7,828 次查看
bhupindersinghk
Thanks Alice_Yang for your reply. I am using FRDM-kl25z128vlk4.
My debugging window looks as below:
While debugging, KDS hangs at 61% as shown in following window:
After this, P&E connection assistant window appears as shown below:
Please suggest the possible solution for this.
7,828 次查看
Hello ,
Have you test   drag and past the attachment i have send you , then debug ?
7,828 次查看
bhupindersinghk
Yes, But no effect
1 more thing, I got a window after P&E connection assistant. It is as shown:
After i cancel the P&E connection assistant window, error in services launch sequence appears.
7,828 次查看
Please test it on other PC , check the problem is the PC or the board .
Alice
7,828 次查看
bhupindersinghk
Hi Alice,
I have tried this on 2 PCs and even i have 2 boards. But I don't know why this problem occur.
Please help me out.
Bhupinder singh Khural
7,828 次查看
bhupindersinghk
Hi Alice,
No.
The same result. It shows first error with pop up window of "P&E connecion assistant" (as shown in above reply). Then the other pop up window shows "Error in services launch sequence".
I don't know where the problem is. I have checked in other system as well as in another kl25z board but it is showing same error.
Please help me out.
7,828 次查看
Hello Bhupinder,
It so strange ! From the debug configuration view , we can see the KDS has detect  the OpenSDA,
it should be connected well .At the Core option, does here have M0+? If have , please select M0+.
And what system do you used ?
If it still can not work , please take a picture for your board connection when debug .
Alice
7,828 次查看
bhupindersinghk
Hello Alice,
There is no M0+ in core option.
I am using KDS 3.0.0 in windows 7 PC. And i have also tried on KDS 1.1.1 in another windows 7 system.
Here, below is the image for connection of frdm kl25z:
Bhupinder singh khural
7,828 次查看
Hello
Please test my project on your side , use the KDS3.0 .
Alice
7,828 次查看
bhupindersinghk
I have tried your project on KDS 3.0 but it is not working.
Same things happened:
1. It showed P&E connection assistant window. (then i close this window and next thing happened)
2. Another window displayed that "Error in services launch sequence"
7,828 次查看
Oh, change one USB line .
7,828 次查看
bhupindersinghk
By changing USB line do you mean to change the USB wire between board and system?
7,828 次查看
Hello Bhupinder,
"I have tried this on 2 PCs and even i have 2 boards" , what about the result ?
Does the other FRDM-KL25 board can work well ?
