Porting project
922件の閲覧回数
kyizawwin
Hi Guys,
I am not sure anyone asked about this. I am a newbie to KDS and just wondering how you guys port one project to another? E.g. I had LED_Blink project and I need to move on to next project Blink_advance which will not be same as LED_Blink but I want to have same setting and PE components. Otherwise, I have to re-configure all PE components.
How you guy handle such situation?
Bryan
タグ(2)
747件の閲覧回数
BlackNight
Hi Bryan,
Processor Expert makes it easy to port to a new project: what I do is this:
a) create a new project for the new device with File > New > Kinetis Project in Eclipse with Processor Expert enabled
b) Copy the components from the first project to the new one.
See Copy of Processor Expert Components | MCU on Eclipse
I hope this helps,
Erich
4 返答(返信)
748件の閲覧回数
BlackNight
Hi Bryan,
I hope this helps,
Erich
747件の閲覧回数
kyizawwin
Hi Erich,
Another strange problem after I copied  PE components. I am using Freedom board KL05Z. I already had working code based on your accelerometer examples code (Thanks for your code). Then I created another project and copied PE components but somehow I2C code is not working at all. I could blink LED. When I debug it showed that the failure at following routine. I used same board for both projects. This is really cracking my head.
  /* Send I2C address plus register address to the I2C bus *without* a stop condition */
  res = CI2C1_MasterSendBlock(deviceData.handle, &addr, 1U, LDD_I2C_NO_SEND_STOP);
  if (res!=ERR_OK) {
    return ERR_FAILED;
Bryan
747件の閲覧回数
BlackNight
You need to check/debug why CI2C1_MasterSendBlock() returns an error code.
Erich
747件の閲覧回数
kyizawwin
Thanks, Erich!
I tried that. Surprisingly, I could not get I2C right at first. So, I tried all sorts of things. Next day, the same code set is working again.
Bryan
