KDS KW41Z Startup process
stevenriedl
I'm new to KDS and the Kinetis series. I am working on a KW41Z Thread/Bluetooth project and I can pretty much understand the examples (Thread router eligible device, gpis interrupt). Where I'm drawing a blank is how the chip startup is run and where to insert my code. I vaguely think it has something to do with the .S file, but between board, devices, drivers, rots and the app, I'm a little confused as to the call order.
Is there a startup guide out there, from power stable to main()?
Hello Steven,
There is a thread about startup sequence of kinetis :
startup sequence in detail of kinetis microcontrollers
The DOC Kerry Zhou recommend  maybe  useful for you:
http://www.nxp.com/assets/documents/data/en/quick-start-guide/KQRUG.pdf?&fpsp=1&WT_TYPE=Quick%20Refe...
And i recommend you first can create a simple project on KDS, then set breakpoint or
debug step by step to check the startup sequence , the startup code all have introduce
in the DOC above .
Hope it helps
Alice Yang
Hello Steven,
in the DOC above .
Hope it helps
Alice Yang
stevenriedl
Thank You, exactly the pointer I was looking for....
Welcome !
