KDS Cannot install, cabinent file is corrupt
3,576 次查看
jason2
I'm trying to install KDS. I am developing for Hexiwear, which according to them requires KDS. When installing I get the following error: "The cabinent file 'disk1.cab' required for this installation is corrupt and cannot be used.". I have tried re-downloading the installer, but get this every time. I'm trying to install on Windows 10. Is my file really corrupt? Has anyone else seen this?
Jason.
3,448 次查看
ZhangJennie
I tested my KDS3.2 install folder on win10 64bit, I didn't have any error.
Can you please try install on another computer?
TIC
3,447 次查看
jason2
Thank you for the suggestion. I was able to install on my Win7 machine. I am disappointed because I prefer to do development on my Win 10 machine.
3,447 次查看
ZhangJennie
Hi Jason.
KDS supports 64bit win10. if you can use the install package on win7, that means the install package should not have problem.
I searched this error in google, this problem should be a system issue rather than KDS install package. I post some of the related discussions I found
Why is disk1.cab corrupt on every software download / install - Microsoft Community
What is Disk1.CAB and How to Fix It? Virus or Safe?
Error: The cabinet file disk1.cab required for this installation is corrupt and can not be used – Su...
Another option I can think of is that, you already installed KDS on win7 computer. Thus you can copy the install folder from win7 machine to your win10 computer. then open KDS from it.
TIC
