How do I remove a Memory Launch Configuration????
892件の閲覧回数
carlnormansuret
Contributor V
I dont remeber what I did but I cant just click and launch anymore, I spent half hour searching everywhere, but tI just cant remove this "T7 Debug [Memcheck]", i have found reference to it here and there but no way to remove it. Its not project specific as I dont get this on my other installation.
タグ(3)
4 返答(返信)
744件の閲覧回数
BlackNight
Hi Carl,
It seems that you have created a memory profile configuration.
Use the following context menu on the project and then you can remove that entry:
I hope this helps,
Erich
744件の閲覧回数
Hello Carl,
Please refer to the step as below:
1.Right click your project , then :
2. Select the debug mode you want to use :
3. Configure it, then click "Debug"
Hope it helps
Alice Yang
744件の閲覧回数
carlnormansuret
Contributor V
That does not fix it, it still comes up with the same thing. I only have one thing to debug, see below
I was trying to work out how to add global varibles in the "variables" window (which i have no idea how on KDS, but on CW10.7 pro i just literally right click and add global. Anyway, I was playing around and I "added memory monitor" or something and now EVERY time i flight the green debug i get that stupid option and I cant remove it. Its still there!!! SO ANNOYING
744件の閲覧回数
Hello Carl,
Please double click"GDB PEMicaro ...." as blow :
Alice
