Debugger not finding the port through the pe multilink.
ソリューションへジャンプ
4,872件の閲覧回数
brendanmerna
I attached some photos showing the issue. I've had this happen before, but generally it's been resolved by a reset of the multilink, the target micro, kinetis, or the computer. But, just recently I had to reset my computer causing me to lose all my applications. I've been reinstalling them trying to get back to where I was, but the multilink continues not to detect the port no matter what I have done. I reinstalled Kinetis studio, I've installed the PE Micro plugins, I've tried all kind of resets, and nothing works.
One thing I noticed different compared to previous times I've used this debugger is that in the debug configuration under the  "GDB PEMicro Interface Debugging" the icon on the left are usually the blue PEMicro symbol where now its just the regular icon. I feel like this is pointing to the route of the problem of an incorrect plugin or driver install.
Does anyone have any ideas?
タグ(2)
4,726件の閲覧回数
brendanmerna
Solution found. When installing the Kinetis Studio the PE Multilink was plugged. This disrupts the PE driver installation and caused my issue. I unplugged the PE Multilink and reinstall Kinetis Studio to fix the problem.
4,727件の閲覧回数
brendanmerna
