Tja1043 Termination Resistors
aiweixin
Dear,
    If the product isn't bus line end node (or the customer requests that the product should not have terminal resistors inside), is two resistors of pin.SPLIT necessary and can be removed?
Labels (2)
guoweisun
像上面这种就是optional的
guoweisun
终端电阻是需要的,没有终端电阻通信不了的,但是这个SPLIT pin可以不用。
aiweixin
您好:
    CAN总线的两端需要加终端电阻,中间的节点(node1、node2)不需要吧。那么中间的节点是否需要R1、R2两个电阻?
guoweisun
像上面这种就是optional的
guoweisun
