TJA1153 - CAN N/W Interface
gopalakrishna
Hi Team,
In one of our automotive application we are using CAN Transceiver IC part No :  TJA1153.
Two CAN transceivers are using in system, one TXer interfacing to S32K322 MCU and another one TXer to other processor.
As transceivers are using in same system, shall I use the common filter and bus components? As board space is constraint.
Thanks.
Gopala
guoweisun
Hi Gopala
 Q:shall I use the common filter and bus components? As board space is constraint.
[GW]Don't suggest you do this.
