PCA9306: Supplying same 3.3V voltage to VREF1 and VREF2
yterada
Is it possible to use PCA9306 with both sides at 3.3V to disconnect I2C buses? Or is there a better solution? Speed is not critical, there will be just 4 slaves on the device side of the bus, other side connected to a pair of GPIOs.
guoweisun
You can evaluate the PCA9617A.
%3CLINGO-SUB%20id%3D%22lingo-sub-2177094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPCA9306%3A%20Supplying%20same%203.3V%20voltage%20to%20VREF1%20and%20VREF2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EIs%20it%20possible%20to%20use%20PCA9306%20with%20both%20sides%20at%203.3V%20to%20disconnect%20I2C%20buses%3F%20Or%20is%20there%20a%20better%20solution%3F%20Speed%20is%20not%20critical%2C%20there%20will%20be%20just%204%20slaves%20on%20the%20device%20side%20of%20the%20bus%2C%20other%20side%20connected%20to%20a%20pair%20of%20GPIOs.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PCA9306%3A%20Supplying%20same%203.3V%20voltage%20to%20VREF1%20and%20VREF2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20can%20evaluate%20the%20PCA9617A.%3C%2FP%3E%3C%2FLINGO-BODY%3E
