Anyone using PEX hardware in a Virtual Desktop Infrastructure setup?
Alicecarry
Hi @nxp
I’ve been testing an environment where NXP’s PEX hardware is used as part of a backend cluster that supports a virtual desktop infrastructure  (VDI). The idea is to connect thin clients to a central host through VDI, but I’m running into a few challenges.
Main things I’m trying to figure out:
  • How to minimize latency and jitter when devices (USB, storage, etc.) run through multiple layers (PEX → hypervisor → VDI).
  • Whether GPU passthrough or SR-IOV is stable enough in this kind of setup.
  • Any best practices for isolating devices securely between different VMs.
So far, I’ve tried pinning some devices to dedicated PCIe lanes and doing a basic GPU passthrough test, but results are mixed. Before I dive deeper, I wanted to ask:
Has anyone here combined NXP PEX hardware with a VDI environment? If yes, what issues did you face, and what worked best for you?
Appreciate any insights or experiences.
%3CLINGO-SUB%20id%3D%22lingo-sub-2175817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAnyone%20using%20PEX%20hardware%20in%20a%20Virtual%20Desktop%20Infrastructure%20setup%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F61445%22%20target%3D%22_blank%22%3E%40nxp%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%E2%80%99ve%20been%20testing%20an%20environment%20where%20NXP%E2%80%99s%20PEX%20hardware%20is%20used%20as%20part%20of%20a%20backend%20cluster%20that%20supports%20a%20%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.lenovo.com%2Fau%2Fen%2Fservers-storage%2Fsolutions%2Fclient-virtualization%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Evirtual%20desktop%20infrastructure%3C%2FA%3E%26nbsp%3B%3C%2FSTRONG%3E%20(VDI).%20The%20idea%20is%20to%20connect%20thin%20clients%20to%20a%20central%20host%20through%20VDI%2C%20but%20I%E2%80%99m%20running%20into%20a%20few%20challenges.%3C%2FP%3E%3CP%3EMain%20things%20I%E2%80%99m%20trying%20to%20figure%20out%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EHow%20to%20minimize%20latency%20and%20jitter%20when%20devices%20(USB%2C%20storage%2C%20etc.)%20run%20through%20multiple%20layers%20(PEX%20%E2%86%92%20hypervisor%20%E2%86%92%20VDI).%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EWhether%20GPU%20passthrough%20or%20SR-IOV%20is%20stable%20enough%20in%20this%20kind%20of%20setup.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EAny%20best%20practices%20for%20isolating%20devices%20securely%20between%20different%20VMs.%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3ESo%20far%2C%20I%E2%80%99ve%20tried%20pinning%20some%20devices%20to%20dedicated%20PCIe%20lanes%20and%20doing%20a%20basic%20GPU%20passthrough%20test%2C%20but%20results%20are%20mixed.%20Before%20I%20dive%20deeper%2C%20I%20wanted%20to%20ask%3A%3C%2FP%3E%3CP%3EHas%20anyone%20here%20combined%20NXP%20PEX%20hardware%20with%20a%20VDI%20environment%3F%20If%20yes%2C%20what%20issues%20did%20you%20face%2C%20and%20what%20worked%20best%20for%20you%3F%3C%2FP%3E%3CP%3EAppreciate%20any%20insights%20or%20experiences.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2175817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EVirtual%20test%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
