micropython lvgl bindings
dsl400
I am trying to use the `micropython` generated code on an actual device and I am having trouble figuring out what version of `lvgl` to use when compiling `micropython`
I tried compiling with 9.2.1 but the bindings do not seem to match
`AttributeError: 'animimg' object has no attribute 'set_playback_time'`
EdwinHz
Hi @dsl400,
Could you please share the project settings as well as the process you take in order to see this issue?
I tried to recreate your issue with a simple project for the MIMXRT1170-EVKB (since I had this board on hand), and added an aimg setting its playback to 0 and 1 (since the issue you describe seems to be related to the playback time). However, I saw no error when running the micropython simulator.
