guiguider v1.9.0 on win11
error when I run the simulator:
Preparing widgets...
Cleaning generated screen files...
Generating C code...
Compiling simulator...
mingw32-make: *** No rule to make target 'C:/Users/Administrator/Desktop/Project/Transplant/transplant/lvgl-simulator/gg_external_data/freemaster/connect_utils.c', needed by 'build/object/connect_utils.o'. Stop. mingw32-make: *** Waiting for unfinished jobs....
Compilation failed!
The path in build/object/connect_utils.o is not consistent with the actual project path(which is D:\Project\Transplant\...\transplantV0.90.20250410\lvgl-simulator\build\object)
How can I solve this problem.
