GUI Guider 1.9.0-GA – Cannot Change Menu Item Positions
1,658件の閲覧回数
yasircagil
I am using GUI Guider 1.9.0-GA and working with the EVK i.MX RT1170 development board.
In my project, I want to change the positions of menu items, but I cannot modify the X and Y coordinates in the GUI Guider interface. I am also unable to manually drag and place the items.
I can adjust the position of items inside the main menu, but, for example, in the battery menu, I am unable to change the item’s coordinates.
Solutions I Have Tried:
I selected the menu item and checked the "Attributes" section, but I couldn't change the X/Y values.
I generated the code and modified the arc_1 position values in MCUXpresso, but it still didn't change.
Can you help me with this? How can I freely position the items?
Thank you!
1,638件の閲覧回数
EdwinHz
Hi @yasircagil,
I tried replicating your issue by using the "DashBoardMenu" example code, but I was able to move all of the components and widgets inside of the menu without any problems. Did you take any particular steps in order to see the issue? Do you also see it on the "DashBoardMenu" example code or does this project work for you?
BR,
Edwin.
