Bug creating new project
已解决
跳至解决方案
2,627 次查看
daniJVV
I have a bug creating a V8.3.2 LVGL project.
Using any board template, then in the "Select application template" I try to use a custom one I did before, and when clicking on "Local Projects" all screen turns white having to close the application.
1 解答
2,599 次查看
ZhangJennie
Hi daniJVV
I tested  "Select application template" under  lvgl V8.3.2, it works well on my side. I couldn't reproduce your issue.
Could you please using the latest GUI Guider and reinstall it ? or test it on another PC?
Jun Zhang.
在原帖中查看解决方案
2 回复数
2,562 次查看
daniJVV
I downloaded the new version, GUI Guider 1.5.1, and there is no "Local projects" option, so there is no problem anymore.
Version 1.5.0:
Version 1.5.1:
2,600 次查看
ZhangJennie
Hi daniJVV
Jun Zhang.
