FreeMaster cannot start in win 10.21H2
jamesli
 I installed FreeMaster 3.0 in a PC with Win 10, I can start it, but the other user (without admin right) login cannot start it, click start and window response with a small circle spinning, sounds try to do something, but the circle disappears and nothing happens.  My questions are: Is FreeMaster designed to run, the user with admin right cannot use it? What I need to do to make the all users to start and use FreeMaster in a shared lab PC. Thank you in advance!  Jian Li
jamesli
Hi, MichalH:
  It works, many thanks!
 Jian
MichalH
NXP Apps Support
NXP Apps Support
please get the latest FreeMASTER 3.1.4 from www.nxp.com/freemaster - this version should fix the issue. Please let me know if this helps.
Michal
jamesli
Hi, MichalH:
 Jian
