FreeMASTAR Lite license
2,288 次查看
naomi_nomura
Dear NXP Technical team,
When installing the FreeMASTAR Lite, license Activation Code is required.
And the total number of license seems to limit to two.
If I want to install the FreeMASTAR Lite to more than three PCs, what should I do?
Naomi Nomura
2,277 次查看
iulian_stan
Hi @naomi_nomura,
The number of licenses was increased on your account - it was limited by a system mistake, by default, we allow a much larger number of registered devices.
Please note that although we allow multiple FreeMASTER Lite licenses per user, and are expected to be used by the original requester. Any NXP registered user can obtain FreeMASTER Lite license free of charge.
Kind regards,
Iulian
2,278 次查看
iulian_stan
Hi @naomi_nomura,
Kind regards,
Iulian
2,265 次查看
naomi_nomura
Dear Iulian,
Thank you very much for your notice.
I understood that multiple FreeMASTER Lite licenses are allowed per user and they are expected to be used by the original requester only.
Naomi Nomura
