Auto connect JLink when application start up
1,941 次查看
LuBiq
I want to capture the initial state of the application. Is there any solution to make FreeMASTER connect target board immediately and automatically when application start up?
2 回复数
1,914 次查看
iulian_stan
Hi @LuBiq,
You can achieve this behavior by simulating a loop in the initialization phase of your application that would wait for a global variable (trigger).
After you connect to the target using FreeMASTER, you can change that variable value to continue application execution. Ex:
volatile char wait = 1; // Trigger variable (to be chnaged from FreeMASTER)
void main() {
  while (wait) {
    // Wait for trigger to change
  // Application logic
Note: this approach will work only with BDM plugin as other plugins require some initializations before you'll be able to connect to the target.
1,873 次查看
LuBiq
I find a very simple solution.
(1) After building, start the application via debug. The application will be suspended at the first code in main() by a breakpoint.
(2) Start communication in FreeMASTER.
(3) Disable all breakpoints, application begins to run.
Can this solution meet my requirement?
%3CLINGO-SUB%20id%3D%22lingo-sub-2265624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%AF%E5%8A%A8%E6%97%B6%E8%87%AA%E5%8A%A8%E8%BF%9E%E6%8E%A5%20JLink%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%83%B3%E6%8D%95%E8%8E%B7%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%88%9D%E5%A7%8B%E7%8A%B6%E6%80%81%E3%80%82%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BB%80%E4%B9%88%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E5%8F%AF%E4%BB%A5%E8%AE%A9FreeMaster%E5%9C%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%AF%E5%8A%A8%E6%97%B6%E7%AB%8B%E5%8D%B3%E8%87%AA%E5%8A%A8%E8%BF%9E%E6%8E%A5%E7%9B%AE%E6%A0%87%E6%9D%BF%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Auto%20connect%20JLink%20when%20application%20start%20up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E7%AE%80%E5%8D%95%E7%9A%84%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E(1)%20%E5%AE%89%E8%A3%85%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E9%80%9A%E8%BF%87%E8%B0%83%E8%AF%95%E5%90%AF%E5%8A%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E7%A8%8B%E5%BA%8F%E5%B0%86%E5%9C%A8%20main()%20%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E4%BB%A3%E7%A0%81%E5%A4%84%E9%80%9A%E8%BF%87%E6%96%AD%E7%82%B9%E6%9A%82%E5%81%9C%E3%80%82%3C%2FP%3E%3CP%3E(2)%20%E5%9C%A8%20FreeMASTER%20%E4%B8%AD%E5%BC%80%E5%A7%8B%E9%80%9A%E4%BF%A1%E3%80%82%3C%2FP%3E%3CP%3E(3)%20%E7%A6%81%E7%94%A8%E6%89%80%E6%9C%89%E6%96%AD%E7%82%B9%EF%BC%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%A7%8B%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E8%83%BD%E6%BB%A1%E8%B6%B3%E6%88%91%E7%9A%84%E8%A6%81%E6%B1%82%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Auto%20connect%20JLink%20when%20application%20start%20up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258053%22%20target%3D%22_blank%22%3E%40LuBiq%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%9C%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E9%98%B6%E6%AE%B5%E6%A8%A1%E6%8B%9F%E4%B8%80%E4%B8%AA%E7%AD%89%E5%BE%85%E5%85%A8%E5%B1%80%E5%8F%98%E9%87%8F%EF%BC%88%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%EF%BC%89%E7%9A%84%E5%BE%AA%E7%8E%AF%E6%9D%A5%E5%AE%9E%E7%8E%B0%E6%AD%A4%E8%A1%8C%E4%B8%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%20FreeMASTER%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%AE%E6%A0%87%E5%90%8E%EF%BC%8C%E5%8F%AF%E6%9B%B4%E6%94%B9%E5%8F%98%E9%87%8F%E5%80%BC%E4%BB%A5%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82Ex%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Evolatile%20char%20wait%20%3D%201%3B%20%2F%2F%20Trigger%20variable%20(to%20be%20chnaged%20from%20FreeMASTER)%0Avoid%20main()%20%7B%0A%20%20while%20(wait)%20%7B%0A%20%20%20%20%2F%2F%20Wait%20for%20trigger%20to%20change%0A%20%20%7D%0A%20%20%2F%2F%20Application%20logic%0A%7D%20%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A4%E6%96%B9%E6%B3%95%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20BDM%20%E6%8F%92%E4%BB%B6%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%85%B6%E4%BB%96%E6%8F%92%E4%BB%B6%E5%9C%A8%E8%BF%9E%E6%8E%A5%E7%9B%AE%E6%A0%87%E4%B9%8B%E5%89%8D%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%BA%9B%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
