FRDM-IMX93 Software Release Package
FRDM-IMX93 Yocto Release - BSP
 Based on i.MX SW 2024 Q3 release
  • Linux kernel: 6.6.36_2.1.0
  • u-boot: 2024.04
Source: https://github.com/nxp-imx-support/meta-imx-frdm
FRDM-IMX93 BSP changes:
  • U-boot: Add basic support for FRDM-IMX93
  • Kernel: Add basic support for FRDM-IMX93 and add support for kinds of accessories
  • GoPoint: Add FRDM-IMX93 support
  • FRDM-IMX93 Yocto layer: Add Yocto layer for FRDM-IMX93 and integrate u-boot/kernel/GoPoint patches
 FRDM-IMX93 accessories
  • 7 inch Waveshare LCD: imx93-11x11-frdm-dsi.dtb
  • 5 inch Tianma LCD: imx93-11x11-frdm-tianma-wvga-panel.dtb
  • RPi-CAM-MIPI: imx93-11x11-frdm.dtb
  • RPI-CAM-INTB: imx93-11x11-frdm-mt9m114.dtb
  • MX93AUD-HAT or MX93AUD-HAT + 8MIC-RPI-MX8: imx93-11x11-frdm-aud-hat.dtb
  • 8MIC-RPI-MX8: imx93-11x11-frdm-8mic.dtb
LCD Panel
Vender
Interface
Size
Resolution
Support Touch
Purchase Link
dtb
T050RDH03-HC
Tianma
24 bit Parallel
5"
800 x 480
No
Will launch with MX91 EVK in Dec'24
7inch Capacitive Touch IPS Display for Raspberry Pi, with Protection Case, 1024×600, DSI Interface
Waveshare
MIPI DSI
7"
1024x600
Yes
Click Here
Camera
Vender
Interface
Size
Resolution
Sensor
Purchase Link
dtb
RPI-CAM-MIPI
onsemi
MIPI CSI
 1/4-inch
1M pixel,
1280H x 800V
AR0144
Click Here
RPI-CAM-INTB
Parallel Camera 40pins
1/6-inch
1.26 Mpixel
1296H ×
976V
MT9M114
Audio
Vender
Interface
Channel
Purchase Link
dtb
MX93AUD-HAT
Cirrus
40pins
8
Click Here
8MIC-RPI-MX8
NXP
40pins
8
Click Here
FRDM-IMX93 Yocto Release Usage
  • Download i.MX SW 2024 Q3 Release:
$ repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-scarthgap -m imx-6.6.36-2.1.0.xml
$ repo sync
  • Integrate FRDM-IMX93 layer into Yocto code base:
$ cd ${MY_YOCTO}/sources
$ git clone https://github.com/nxp-imx-support/meta-imx-frdm.git
  • Yocto Project Setup:
$ MACHINE=imx93frdm DISTRO=fsl-imx-xwayland source sources/meta-imx-frdm/tools/imx-frdm-setup.sh -b frdm-imx93
  • Build images:
$ bitbake imx-image-full
  • Flashing SD card image:
$ zstdcat imx-image-full-imx93frdm.rootfs.wic.zst | sudo dd of=/dev/sdb bs=1M && sync
  • Using uuu to burn image and rootfs to SD:
$ uuu -b sd_all imx-image-full-imx93frdm.rootfs.wic.zst
FRDM-IMX93 Yocto Release – Matter support
Based on i.MX Matter 2024 Q3
Usage:
−Download i.MX SW 2024 Q3 Release;
−Download i.MX Matter 2024 Q3;
  • $ cd ${MY_YOCTO}/sources/meta-nxp-connectivity
  • $ git remote update
  • $ git checkout imx_matter_2024_q3
−Download FRDM-IMX93 Layer:
−Yocto Project Setup:
  • $ MACHINE=imx93frdm-iwxxx-matter DISTRO=fsl-imx-xwayland source sources/meta-imx-frdm/tools/imx-frdm-matter-setup.sh bld-xwayland-imx93
−Build images:
  • $ bitbake imx-image-multimedia
FRDM-MX93 Debian Release
Debian is a free Operating System (OS), also known as Debian GNU/Linux.
i.MX Debian Linux SDK distribution is a combination of NXP-provided kernel and boot loaders with a Debian distro user-space image.
−Debian 12
−NXP packages are based i.MX SW Release 2024 Q3
  • i.MX Debian Linux SDK distribution uses Flexbuild to build system.
−Debian-based RootFS;
  • Debian Base (basic packages)
  • Debian Server (more packages without GUI Desktop)
  • Debian Desktop (with GNOME GUI Desktop)
−Linux kernel;
−BSP components;
−various  applications (graphics, multimedia, networking, connectivity, security, and AI/ML);
 Quick Start with Debian
Flexbuild compiles and assembles the distro images as three parts:
  • BSP firmware image
  • Boot image
  • RootFS image
Creating an SD card on the Linux host
  • Download flex-installer
−$ wget http://www.nxp.com/lgfiles/sdk/lsdk2406/flex-installer
−$ chmod +x flex-installer; sudo mv flex-installer /usr/bin
  • Plug the SD card into the Linux host and install the images as below:
−$ flex-installer -i pf -d /dev/sdb (format SD card)
−$ flex-installer -i auto -d /dev/mmcblk1 -m imx93frdm (automatically download and install images)
  • Plug the SD card into the i.MX board and install the extra packages as follows:
−$ dhclient -i end0 (setup Ethernet network interface by DHCP or setting it manually)
−$ date -s "22 Nov 2024 09:00:00" (setting correct system time is required)
−$ debian-post-install-pkg desktop (install extra packages for GNOME GUI Desktop version)
−or
−$ debian-post-install-pkg server (install extra packages for Server version without GUI Desktop)
−# After finishing the installation, run the reboot command to boot up the Debian Desktop/Server system.
Building Debian Images with Flexbuild
  • Run the following commands for the first time to set up the build environment:
−$ git clone https://github.com/nxp/flexbuild
−$ cd flexbuild && . setup.env
−#Continue to run commands below in case  you need to  build in Docker due to lack of Ubuntu 22.04 or Debian 12 host
−$ bld docker (create or attach a docker container)
−$ . setup.env
  • Flexbuild usage:
−$ bld -m imx93frdm (build all images for imx93frdm)
−$ bld uboot -m imx93frdm (compile u-boot image for imx93frdm)
−$ bld linux (compile linux kernel for all arm64 i.MX machines)
−$ bld bsp -m imx93frdm (generate BSP firmware)
−$ bld boot (generate boot partition tarball including kernel, dtb, modules, distro bootscript for iMX machines)
−$ bld multimedia (build multimedia components for i.MX platforms)
−$ bld rfs -r debian:base (generate Debian base rootfs with base packages)
−$ bld apps -r debian:server (compile apps against runtime dependencies of Debian server RootFS)
−$ bld merge-apps -r debian:server (merge iMX-specific apps into target Debian server RootFS)
−$ bld packrfs (pack and compress target rootfs)
Related Documentation
FRDM-IMX93 Documents:
More information about i.MX productions can be found at(http://www.nxp.com/imxlinux)
Debian documents at http://www.nxp.com/nxpdebian
%3CLINGO-SUB%20id%3D%22lingo-sub-2024217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-IMX93%20%E8%BD%AF%E4%BB%B6%E5%8F%91%E5%B8%83%E5%8C%85%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2024217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CH3%20id%3D%22toc-hId-1942392249%22%20id%3D%22toc-hId-2004210745%22%3E%3CSTRONG%3EFRDM-IMX93%20%3C%2FSTRONG%3E%3CSTRONG%3EYocto%3C%2FSTRONG%3E%3CSTRONG%3E%E5%8F%91%E5%B8%83%20-%20BSP%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3CP%3E%26nbsp%3B%3CSPAN%3E%E5%9F%BA%E4%BA%8E%20i.MX%20SW%202024%20Q3%20%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ELinux%20kernel%3A%206.6.36_2.1.0%3C%2FLI%3E%0A%3CLI%3Eu-boot%3A%202024.04%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm%3C%2FA%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3EFRDM-IMX93%20BSP%20%E5%8F%98%E6%9B%B4%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EU-Boot%EF%BC%9A%E6%B7%BB%E5%8A%A0%E5%AF%B9%20FRDM-IMX93%20%E7%9A%84%E5%9F%BA%E6%9C%AC%E6%94%AF%E6%8C%81%3C%2FLI%3E%0A%3CLI%3E%E5%86%85%E6%A0%B8%EF%BC%9A%E4%B8%BA%20FRDM-IMX93%20%E6%B7%BB%E5%8A%A0%E5%9F%BA%E7%A1%80%E6%94%AF%E6%8C%81%E5%B9%B6%E6%94%AF%E6%8C%81%E5%A4%9A%E7%A7%8D%E9%85%8D%E4%BB%B6%3C%2FLI%3E%0A%3CLI%3E%E9%87%8D%E7%82%B9%EF%BC%9A%E6%B7%BB%E5%8A%A0%20FRDM-IMX93%20%E6%94%AF%E6%8C%81%3C%2FLI%3E%0A%3CLI%3EFRDM-IMX93%20Yocto%20%E5%B1%82%EF%BC%9A%E4%B8%BA%20FRDM-IMX93%20%E6%B7%BB%E5%8A%A0%20Yocto%20%E5%B1%82%E5%B9%B6%E9%9B%86%E6%88%90%20u-boot%2Fkernel%2FGoPoint%20%E8%A1%A5%E4%B8%81%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nxf78977_0-1736356887580.png%22%20style%3D%22width%3A%20435px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nxf78977_0-1736356887580.png%22%20style%3D%22width%3A%20435px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318626i35D837C752D451DA%2Fimage-dimensions%2F435x462%3Fv%3Dv2%22%20width%3D%22435%22%20height%3D%22462%22%20role%3D%22button%22%20title%3D%22nxf78977_0-1736356887580.png%22%20alt%3D%22nxf78977_0-1736356887580.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Enxf78977_0-1736356887580.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%20%3CSTRONG%3EFRDM-IMX93%20%E9%85%8D%E4%BB%B6%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E7%E8%8B%B1%E5%AF%B8Waveshare%20LCD%EF%BC%9A%3CEM%3Eimx93-11x11-frdm-dsi.dtb%3C%2FEM%3E%3C%2FLI%3E%0A%3CLI%3E5%20inch%20Tianma%20LCD%3A%20%3CEM%3Eimx93-11x11-frdm-tianma-wvga-panel.dtb%3C%2FEM%3E%3C%2FLI%3E%0A%3CLI%3ERPi-CAM-MIPI%3A%26nbsp%3B%3CEM%3Eimx93-11x11-frdm.dtb%3C%2FEM%3E%3C%2FLI%3E%0A%3CLI%3ERPI-CAM-INTB%3A%26nbsp%3B%3CEM%3Eimx93-11x11-frdm-mt9m114.dtb%3C%2FEM%3E%3C%2FLI%3E%0A%3CLI%3EMX93AUD-HAT%20or%20MX93AUD-HAT%20%2B%208MIC-RPI-MX8%3A%26nbsp%3B%3CEM%3Eimx93-11x11-frdm-aud-hat.dtb%3C%2FEM%3E%3C%2FLI%3E%0A%3CLI%3E8MIC-RPI-MX8%3A%20%3CEM%3Eimx93-11x11-frdm-8mic.dtb%3C%2FEM%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20width%3D%22982%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22140%22%3E%0A%3CP%3E%3CSTRONG%3ELCD%20%E9%9D%A2%E6%9D%BF%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2286%22%3E%0A%3CP%3E%3CSTRONG%3EVender%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22185%22%3E%0A%3CP%3E%3CSTRONG%3E%E6%8E%A5%E5%8F%A3%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2273%22%3E%0A%3CP%3E%3CSTRONG%3E%E5%A4%A7%E5%B0%8F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%3E%0A%3CP%3E%3CSTRONG%3E%E8%A7%A3%E5%86%B3%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2284%22%3E%0A%3CP%3E%3CSTRONG%3E%E6%94%AF%E6%8C%81%E8%A7%A6%E6%8E%A7%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22114%22%3E%0A%3CP%3E%3CSTRONG%3E%E8%B4%AD%E4%B9%B0%E9%93%BE%E6%8E%A5%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22195%22%3E%0A%3CP%3E%3CSTRONG%3Edtb%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22140%22%3E%0A%3CP%3ET050RDH03-HC%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2286%22%3E%0A%3CP%3ETianma%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22185%22%3E%0A%3CP%3E24%E4%BD%8D%E5%B9%B6%E8%A1%8C%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2273%22%3E%0A%3CP%3E5%20%E8%8B%B1%E5%AF%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%3E%0A%3CP%3E800%20x%20480%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2284%22%3E%0A%3CP%3ENo%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22114%22%3E%0A%3CP%3E%E5%B0%86%E4%BA%8E%202024%20%E5%B9%B4%2012%20%E6%9C%88%E9%9A%8F%20MX91%20EVK%20%E6%8E%A8%E5%87%BA%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22195%22%3E%0A%3CP%3Eimx93-11x11-frdm-tianma-wvga-panel.dtb%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22140%22%3E%0A%3CP%3E%3CU%3E%3CA%20href%3D%22https%3A%2F%2Fwww.waveshare.com%2Fproduct%2Fraspberry-pi%2Fdisplays%2Flcd-oled%2F7inch-dsi-lcd-c.htm%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E7%20%E8%8B%B1%E5%AF%B8%E7%94%B5%E5%AE%B9%E5%BC%8F%E8%A7%A6%E6%91%B8%20IPS%20%E6%98%BE%E7%A4%BA%E5%B1%8F%EF%BC%88%E9%80%82%E7%94%A8%E4%BA%8E%E6%A0%91%E8%8E%93%E6%B4%BE%EF%BC%89%EF%BC%8C%E5%B8%A6%E4%BF%9D%E6%8A%A4%E5%A3%B3%EF%BC%8C1024%C3%97600%20%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%8CDSI%20%E6%8E%A5%E5%8F%A3%3C%2FA%3E%3C%2FU%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2286%22%3E%0A%3CP%3EWaveshare%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22185%22%3E%0A%3CP%3EMIPI%20DSI%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2273%22%3E%0A%3CP%3E7%E8%8B%B1%E5%AF%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%3E%0A%3CP%3E1024x600%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2284%22%3E%0A%3CP%3E%E6%98%AF%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22114%22%3E%0A%3CP%3E%3CU%3E%3CA%20href%3D%22https%3A%2F%2Fwww.waveshare.com%2Fproduct%2Fraspberry-pi%2Fdisplays%2Flcd-oled%2F7inch-dsi-lcd-c.htm%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E7%82%B9%E5%87%BB%E6%AD%A4%E5%A4%84%3C%2FA%3E%3C%2FU%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22195%22%3E%0A%3CP%3Eimx93-11x11-frdm-dsi.dtb%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22140%22%3E%0A%3CP%3E%3CSTRONG%3E%E6%91%84%E5%83%8F%E5%A4%B4%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2286%22%3E%0A%3CP%3E%3CSTRONG%3EVender%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22185%22%3E%0A%3CP%3E%3CSTRONG%3E%E6%8E%A5%E5%8F%A3%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2273%22%3E%0A%3CP%3E%3CSTRONG%3E%E5%A4%A7%E5%B0%8F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%3E%0A%3CP%3E%3CSTRONG%3E%E8%A7%A3%E5%86%B3%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2284%22%3E%0A%3CP%3E%3CSTRONG%3E%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22114%22%3E%0A%3CP%3E%3CSTRONG%3E%E8%B4%AD%E4%B9%B0%E9%93%BE%E6%8E%A5%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22195%22%3E%0A%3CP%3E%3CSTRONG%3Edtb%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22140%22%3E%0A%3CP%3ERPI-CAM-MIPI%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2286%22%3E%0A%3CP%3Eonsemi%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22185%22%3E%0A%3CP%3EMIPI%20CSI%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2273%22%3E%0A%3CP%3E1%2F4%E8%8B%B1%E5%AF%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%3E%0A%3CP%3E100%20%E4%B8%87%E5%83%8F%E7%B4%A0%EF%BC%8C1280H%20%C3%97%20800V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2284%22%3E%0A%3CP%3EAR0144%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22114%22%3E%0A%3CP%3E%3CU%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fi-mx-evaluation-and-development-boards%2Frpi-cam-mipi%3ARPI-CAM-MIPI%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E7%82%B9%E5%87%BB%E6%AD%A4%E5%A4%84%3C%2FA%3E%3C%2FU%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22195%22%3E%0A%3CP%3Eimx93-11x11-frdm.dtb%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22140%22%3E%0A%3CP%3ERPI-CAM-INTB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2286%22%3E%0A%3CP%3E%E3%80%80%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22185%22%3E%0A%3CP%3E%E5%B9%B6%E8%A1%8C%E6%91%84%E5%83%8F%E5%A4%B4%2040%E9%92%88%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2273%22%3E%0A%3CP%3E1%2F6%E8%8B%B1%E5%AF%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%3E%0A%3CP%3E1.26%20Mpixel%3CBR%20%2F%3E1296H%20%C3%97%3CBR%20%2F%3E976V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2284%22%3E%0A%3CP%3EMT9M114%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22114%22%3E%0A%3CP%3E%E5%B0%86%E4%BA%8E%202024%20%E5%B9%B4%2012%20%E6%9C%88%E9%9A%8F%20MX91%20EVK%20%E6%8E%A8%E5%87%BA%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22195%22%3E%0A%3CP%3Eimx93-11x11-frdm-mt9m114.dtb%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22140%22%3E%0A%3CP%3E%3CSTRONG%3E%E9%9F%B3%E9%A2%91%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2286%22%3E%0A%3CP%3E%3CSTRONG%3EVender%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22185%22%3E%0A%3CP%3E%3CSTRONG%3E%E6%8E%A5%E5%8F%A3%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2273%22%3E%0A%3CP%3E%3CSTRONG%3E%E9%80%9A%E9%81%93%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%3E%0A%3CP%3E%3CSTRONG%3E%E3%80%80%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2284%22%3E%0A%3CP%3E%3CSTRONG%3E%E3%80%80%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22114%22%3E%0A%3CP%3E%3CSTRONG%3E%E8%B4%AD%E4%B9%B0%E9%93%BE%E6%8E%A5%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22195%22%3E%0A%3CP%3E%3CSTRONG%3Edtb%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22140%22%3E%0A%3CP%3EMX93AUD-HAT%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2286%22%3E%0A%3CP%3ECirrus%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22185%22%3E%0A%3CP%3E40%E9%92%88%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2273%22%3E%0A%3CP%3E8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%3E%0A%3CP%3E%E3%80%80%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2284%22%3E%0A%3CP%3E%E3%80%80%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22114%22%3E%0A%3CP%3E%3CU%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fi-mx-evaluation-and-development-boards%2Fmx93aud-hat%3AMX93AUD-HAT%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E7%82%B9%E5%87%BB%E6%AD%A4%E5%A4%84%3C%2FA%3E%3C%2FU%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22195%22%3E%0A%3CP%3Eimx93-11x11-frdm-aud-hat.dtb%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22140%22%3E%0A%3CP%3E8MIC-RPI-MX8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2286%22%3E%0A%3CP%3ENXP%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22185%22%3E%0A%3CP%3E40%E9%92%88%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2273%22%3E%0A%3CP%3E8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%3E%0A%3CP%3E%E3%80%80%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2284%22%3E%0A%3CP%3E%E3%80%80%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22114%22%3E%0A%3CP%3E%3CU%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2F8MIC-RPI-MX8%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E7%82%B9%E5%87%BB%E6%AD%A4%E5%A4%84%3C%2FA%3E%3C%2FU%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22195%22%3E%0A%3CP%3Eimx93-11x11-frdm-8mic.dtb%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3EFRDM-IMX93%20%3C%2FSTRONG%3E%3CSTRONG%3EYocto%3C%2FSTRONG%3E%3CSTRONG%3E%20%E7%89%88%E6%9C%AC%E4%BD%BF%E7%94%A8%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E4%B8%8B%E8%BD%BD%20i.MX%20SW%202024%20Q3%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20repo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%3C%2FA%3E%20-b%20imx-linux-scarthgap%20-m%20imx-6.6.36-2.1.0.xml%3C%2FP%3E%0A%3CP%3E%24%20repo%20sync%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%E5%B0%86%20FRDM-IMX93%20%E5%B1%82%E9%9B%86%E6%88%90%E5%88%B0%20Yocto%20%E4%BB%A3%E7%A0%81%E5%BA%93%E4%B8%AD%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cd%20%24%7BMY_YOCTO%7D%2Fsources%3C%2FP%3E%0A%3CP%3E%24%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm.git%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm.git%3C%2FA%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3EYocto%20%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20MACHINE%3Dimx93frdm%20DISTRO%3Dfsl-imx-xwayland%20source%20sources%2Fmeta-imx-frdm%2Ftools%2Fimx-frdm-setup.sh%20-b%20frdm-imx93%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%E6%9E%84%E5%BB%BA%E9%95%9C%E5%83%8F%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%20imx-image-full%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%E7%83%A7%E5%BD%95%20SD%20%E5%8D%A1%E9%95%9C%E5%83%8F%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20zstdcat%20imx-image-full-imx93frdm.rootfs.wic.zst%20%7C%20sudo%20dd%20of%3D%2Fdev%2Fsdb%20bs%3D1M%20%26amp%3B%26amp%3B%20sync%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%E4%BD%BF%E7%94%A8%20uuu%20%E5%B7%A5%E5%85%B7%E5%B0%86%E9%95%9C%E5%83%8F%E5%92%8C%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E7%83%A7%E5%BD%95%E8%87%B3%20SD%20%E5%8D%A1%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20uuu%20-b%20sd_all%20imx-image-full-imx93frdm.rootfs.wic.zst%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3EFRDM-IMX93%20%3C%2FSTRONG%3E%3CSTRONG%3EYocto%3C%2FSTRONG%3E%3CSTRONG%3E%20%E5%8F%91%E5%B8%83%20%E2%80%93%20Matter%20%E6%94%AF%E6%8C%81%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E5%9F%BA%E4%BA%8E%20i.MX%20Matter%202024%20Q3%3C%2FP%3E%0A%3CP%3E%E7%94%A8%E6%B3%95%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E2%88%92%20%E4%B8%8B%E8%BD%BD%20i.MX%20SW%202024%20Q3%20%E7%89%88%E6%9C%AC%EF%BC%9B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%24%20repo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%3C%2FA%3E%20-b%20imx-linux-scarthgap%20-m%20imx-6.6.36-2.1.0.xml%3C%2FLI%3E%0A%3CLI%3E%24%20repo%20sync%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92%E4%B8%8B%E8%BD%BD%20i.MX%20Matter%202024%20Q3%EF%BC%9B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%24%20cd%20%24%7BMY_YOCTO%7D%2Fsources%2Fmeta-nxp-connectivity%3C%2FLI%3E%0A%3CLI%3E%24%20git%20remote%20update%3C%2FLI%3E%0A%3CLI%3E%24%20git%20checkout%20imx_matter_2024_q3%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92%E4%B8%8B%E8%BD%BDFRDM-IMX93%E5%B1%82%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%24%20cd%20%24%7BMY_YOCTO%7D%2Fsources%3C%2FLI%3E%0A%3CLI%3E%24%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm.git%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm.git%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92%20Yocto%20%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%24%20MACHINE%3Dimx93frdm-iwxxx-matter%20DISTRO%3Dfsl-imx-xwayland%20source%20sources%2Fmeta-imx-frdm%2Ftools%2Fimx-frdm-matter-setup.sh%20bld-xwayland-imx93%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92%20%E6%9E%84%E5%BB%BA%E9%95%9C%E5%83%8F%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%24%20bitbake%20imx-image-multimedia%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nxf78977_1-1736357401734.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nxf78977_1-1736357401734.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318628i70C948533D2E33AC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nxf78977_1-1736357401734.png%22%20alt%3D%22nxf78977_1-1736357401734.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Enxf78977_1-1736357401734.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId-134937786%22%20id%3D%22toc-hId-196756282%22%3E%3CSTRONG%3EFRDM-MX93%20Debian%E5%8F%91%E8%A1%8C%E7%89%88%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3CP%3EDebian%20%E6%98%AF%E4%B8%80%E4%B8%AA%E5%85%8D%E8%B4%B9%E7%9A%84%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%EF%BC%88OS%EF%BC%89%EF%BC%8C%E4%B9%9F%E7%A7%B0%E4%B8%BA%20Debian%20GNU%2FLinux%E3%80%82%3C%2FP%3E%0A%3CP%3Ei.MX%20Debian%20Linux%20SDK%20%E5%8F%91%E8%A1%8C%E7%89%88%E7%BB%93%E5%90%88%E4%BA%86%20NXP%20%E6%8F%90%E4%BE%9B%E7%9A%84%E5%86%85%E6%A0%B8%E3%80%81%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B8%8E%20Debian%20%E5%8F%91%E8%A1%8C%E7%89%88%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E9%95%9C%E5%83%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E2%88%92Debian%2012%3C%2FP%3E%0A%3CP%3E%E2%88%92%20NXP%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%9F%BA%E4%BA%8E%20i.MX%20SW%202024%20Q3%20%E7%89%88%E6%9C%AC%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Ei.MX%20Debian%20Linux%20SDK%20%E5%8F%91%E8%A1%8C%E7%89%88%E4%BD%BF%E7%94%A8%20Flexbuild%20%E6%9D%A5%E6%9E%84%E5%BB%BA%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92%E5%9F%BA%E4%BA%8E%20Debian%20%E7%9A%84%20RootFS%EF%BC%9B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EDebian%20%E5%9F%BA%E7%A1%80%E7%89%88%EF%BC%88%E5%9F%BA%E7%A1%80%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%89%3C%2FLI%3E%0A%3CLI%3EDebian%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%89%88%EF%BC%88%E6%9B%B4%E5%A4%9A%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%8C%E6%97%A0%E5%9B%BE%E5%BD%A2%E6%A1%8C%E9%9D%A2%EF%BC%89%3C%2FLI%3E%0A%3CLI%3EDebian%20%E6%A1%8C%E9%9D%A2%E7%89%88%EF%BC%88%E5%B8%A6%20GNOME%20%E5%9B%BE%E5%BD%A2%E7%95%8C%E9%9D%A2%EF%BC%89%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92Linux%20kernel%3B%3C%2FP%3E%0A%3CP%3E%E2%88%92BSP%20%E7%BB%84%E4%BB%B6%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%E2%88%92%20%E6%94%AF%E6%8C%81%E5%A4%9A%E7%A7%8D%E5%BA%94%E7%94%A8%EF%BC%88%E5%9B%BE%E5%BD%A2%E3%80%81%E5%A4%9A%E5%AA%92%E4%BD%93%E3%80%81%E7%BD%91%E7%BB%9C%E3%80%81%E8%BF%9E%E6%8E%A5%E3%80%81%E5%AE%89%E5%85%A8%E5%8F%8A%20AI%2FML%EF%BC%89%EF%BC%9B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fflexbuild%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fflexbuild%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%E4%BB%8B%E7%BB%8D%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fnxp.com%2Fnxpdebian%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.com%2Fnxpdebian%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%3CSTRONG%3EDebian%20%E5%BF%AB%E9%80%9F%E5%85%A5%E9%97%A8%E6%8C%87%E5%8D%97%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EFlexbuild%20%E5%B0%86%E5%8F%91%E8%A1%8C%E7%89%88%E9%95%9C%E5%83%8F%E7%BC%96%E8%AF%91%E5%B9%B6%E7%BB%84%E8%A3%85%E4%B8%BA%E4%B8%89%E9%83%A8%E5%88%86%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EBSP%20%E5%9B%BA%E4%BB%B6%E6%98%A0%E5%83%8F%3C%2FLI%3E%0A%3CLI%3E%E5%90%AF%E5%8A%A8%E9%95%9C%E5%83%8F%3C%2FLI%3E%0A%3CLI%3ERootFS%20%E9%95%9C%E5%83%8F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%9C%A8%20Linux%20%E4%B8%BB%E6%9C%BA%E4%B8%8A%E5%88%9B%E5%BB%BA%20SD%20%E5%8D%A1%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E4%B8%8B%E8%BD%BD%20flex-installer%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92%24%20wget%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fsdk%2Flsdk2406%2Fflex-installer%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fsdk%2Flsdk2406%2Fflex-installer%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20chmod%20%2Bx%20flex-installer%EF%BC%9Bsudo%20mv%20flex-installer%20%2Fusr%2Fbin%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%B0%86%20SD%20%E5%8D%A1%E6%8F%92%E5%85%A5%20Linux%20%E4%B8%BB%E6%9C%BA%E5%B9%B6%E6%8C%89%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E5%AE%89%E8%A3%85%E9%95%9C%E5%83%8F%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92%24%20flex-installer%20-i%20pf%20-d%20%2Fdev%2Fsdb%EF%BC%88%E6%A0%BC%E5%BC%8F%E5%8C%96%20SD%20%E5%8D%A1%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20flex-installer%20-i%20auto%20-d%20%2Fdev%2Fmmcblk1%20-m%20imx93frdm%EF%BC%88%E8%87%AA%E5%8A%A8%E4%B8%8B%E8%BD%BD%E5%B9%B6%E5%AE%89%E8%A3%85%E9%95%9C%E5%83%8F%EF%BC%89%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%B0%86%20SD%20%E5%8D%A1%E6%8F%92%E5%85%A5%20i.MX%20%E6%9D%BF%EF%BC%8C%E5%B9%B6%E6%8C%89%E5%A6%82%E4%B8%8B%E6%96%B9%E5%BC%8F%E5%AE%89%E8%A3%85%E9%A2%9D%E5%A4%96%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92%24%20dhclient%20-i%20end0%20%EF%BC%88%E9%80%9A%E8%BF%87%20DHCP%20%E6%88%96%E6%89%8B%E5%8A%A8%E8%AE%BE%E7%BD%AE%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20date%20-s%20%222024%E5%B9%B411%E6%9C%8822%E6%97%A5%2009%3A00%3A00%22%EF%BC%88%E9%9C%80%E8%A6%81%E8%AE%BE%E7%BD%AE%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%97%B4%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20debian-post-install-pkg%20desktop%20%EF%BC%88%E4%B8%BA%20GNOME%20%E5%9B%BE%E5%BD%A2%E6%A1%8C%E9%9D%A2%E7%89%88%E5%AE%89%E8%A3%85%E9%A2%9D%E5%A4%96%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%E6%88%96%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20debian-post-install-pkg%20server%20%EF%BC%88%E4%B8%BA%E6%97%A0%E5%9B%BE%E5%BD%A2%E6%A1%8C%E9%9D%A2%E7%9A%84%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%89%88%E5%AE%89%E8%A3%85%E9%A2%9D%E5%A4%96%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%23%20%E5%AE%8C%E6%88%90%E5%AE%89%E8%A3%85%E5%90%8E%EF%BC%8C%E8%BF%90%E8%A1%8C%20reboot%20%E5%91%BD%E4%BB%A4%E4%BB%A5%E5%90%AF%E5%8A%A8%20Debian%20Desktop%2FServer%20%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%20%3CSTRONG%3EFlexbuild%3C%2FSTRONG%3E%20%3CSTRONG%3E%E6%9E%84%E5%BB%BA%20Debian%20%E9%95%9C%E5%83%8F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E9%A6%96%E6%AC%A1%E8%BF%90%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E4%BB%A5%E8%AE%BE%E7%BD%AE%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92%24%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp%2Fflexbuild%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp%2Fflexbuild%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20cd%20flexbuild%20%26amp%3B%26amp%3B%20.%20setup.env%3C%2FP%3E%0A%3CP%3E%E2%88%92%23%20%E8%8B%A5%E5%9B%A0%E7%BC%BA%E5%B0%91%20Ubuntu%2022.04%20%E6%88%96%20Debian%2012%20%E4%B8%BB%E6%9C%BA%E9%9C%80%E5%9C%A8%20Docker%20%E4%B8%AD%E6%9E%84%E5%BB%BA%EF%BC%8C%E8%AF%B7%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20bld%20docker%EF%BC%88%E5%88%9B%E5%BB%BA%E6%88%96%E9%99%84%E5%8A%A0%20docker%20%E5%AE%B9%E5%99%A8%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20.%20setup.env%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3EFlexbuild%20%E4%BD%BF%E7%94%A8%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E2%88%92%24%20bld%20-m%20imx93frdm%EF%BC%88%E6%9E%84%E5%BB%BA%20imx93frdm%20%E7%9A%84%E6%89%80%E6%9C%89%E6%98%A0%E5%83%8F%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20bld%20uboot%20-m%20imx93frdm%EF%BC%88%E7%BC%96%E8%AF%91%20imx93frdm%20%E7%9A%84%20u-boot%20%E9%95%9C%E5%83%8F%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20bld%20linux%20%EF%BC%88%E4%B8%BA%E6%89%80%E6%9C%89%20arm64%20i.MX%20%E8%AE%BE%E5%A4%87%E7%BC%96%E8%AF%91%20Linux%20%E5%86%85%E6%A0%B8%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20bld%20bsp%20-m%20imx93frdm%20%EF%BC%88%E7%94%9F%E6%88%90%20BSP%20%E5%9B%BA%E4%BB%B6%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20bld%20boot%20%EF%BC%88%E7%94%9F%E6%88%90%E5%8C%85%E5%90%AB%E5%86%85%E6%A0%B8%E3%80%81dtb%E3%80%81%E6%A8%A1%E5%9D%97%E5%92%8C%20i.MX%20%E8%AE%BE%E5%A4%87%E5%8F%91%E8%A1%8C%E7%89%88%E5%90%AF%E5%8A%A8%E8%84%9A%E6%9C%AC%E7%9A%84%E5%90%AF%E5%8A%A8%E5%88%86%E5%8C%BA%E5%8E%8B%E7%BC%A9%E5%8C%85%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20bld%20multimedia%EF%BC%88%E6%9E%84%E5%BB%BA%20i.MX%20%E5%B9%B3%E5%8F%B0%E7%9A%84%E5%A4%9A%E5%AA%92%E4%BD%93%E7%BB%84%E4%BB%B6%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20bld%20rfs%20-r%20debian%3Abase%20%EF%BC%88%E7%94%9F%E6%88%90%E5%8C%85%E5%90%AB%E5%9F%BA%E7%A1%80%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%9A%84%20Debian%20%E5%9F%BA%E7%A1%80%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20bld%20apps%20-r%20debian%3Aserver%20%EF%BC%88%E9%92%88%E5%AF%B9%20Debian%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%89%88%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E7%9A%84%E8%BF%90%E8%A1%8C%E6%97%B6%E4%BE%9D%E8%B5%96%E7%BC%96%E8%AF%91%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20bld%20merge-apps%20-r%20debian%3Aserver%EF%BC%88%E5%B0%86%20iMX%20%E7%89%B9%E5%AE%9A%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%88%E5%B9%B6%E5%88%B0%E7%9B%AE%E6%A0%87%20Debian%20%E6%9C%8D%E5%8A%A1%E5%99%A8%20RootFS%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E2%88%92%24%20bld%20packrfs%20(%E6%89%93%E5%8C%85%E5%B9%B6%E5%8E%8B%E7%BC%A9%E7%9B%AE%E6%A0%87%20rootfs)%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId--1672516677%22%20id%3D%22toc-hId--1610698181%22%3E%3CSTRONG%3E%E7%9B%B8%E5%85%B3%E6%96%87%E6%A1%A3%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3CBR%20%2F%3E%0A%3CP%3EFRDM-IMX93%20%E6%96%87%E6%A1%A3%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-frdm-imx93%3AGS-FRDM-IMX93%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFRDM-IMX93%E5%BF%AB%E9%80%9F%E5%85%A5%E9%97%A8%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUM12181%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFRDM-IMX93%E6%9D%BF%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10195%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFRDM-IMX93%20%E8%BD%AF%E4%BB%B6%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E6%9B%B4%E5%A4%9A%20i.MX%20%E4%BA%A7%E5%93%81%E4%BF%A1%E6%81%AF%E8%AF%B7%E8%AE%BF%E9%97%AE%20(%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fimxlinux%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fimxlinux%3C%2FA%3E)%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_YOCTO_PROJECT_USERS_GUIDE.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%20%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_YOCTO_PROJECT_USERS_GUIDE.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EYocto%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_YOCTO_PROJECT_USERS_GUIDE.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20%E9%A1%B9%E7%9B%AE%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_LINUX_USERS_GUIDE.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%20Linux%20User%E2%80%99s%20Guide%E2%80%8B%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Freference-manual%2FIMX_REFERENCE_MANUAL.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%20Linux%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E2%80%8B%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_PORTING_GUIDE.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%20%E7%A7%BB%E6%A4%8D%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EDebian%20%E6%96%87%E6%A1%A3%E8%AF%A6%E8%A7%81%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fnxpdebian%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fnxpdebian%3C%2FA%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CU%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUG10155%2Fpage%2Ftopics%2Foverview.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%20Debian%20Linux%20SDK%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2024217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFRDM-IMX93%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EFRDM%20%E5%9F%B9%E8%AE%AD%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%E5%BA%94%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCU%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E6%97%A0%E7%BA%BF%E8%BF%9E%E6%8E%A5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
100% 有帮助 (1/1)
版本历史
最后更新:
‎01-10-2025 08:24 AM
更新人:
