FRDM-IMX91 Software Release Introduction
i.MX FRDM Development (FRDM) software release contains prebuilt images, documentation, and i.MX FRDM Yocto layer for FRDM-IMX boards. It also includes support for Matter and Debian release. This article will give a brief introduction of FRDM-IMX91 software release. For more details, please check i.MX FRDM Software User Guide.
FRDM-IMX91 Yocto BSP Release
Based on i.MX SW 2024 Q3 BSP release
  • Linux kernel: 6.6.36_2.1.0
  • u-boot: 2024.04
i.MX FRDM Yocto layer source: https://github.com/nxp-imx-support/meta-imx-frdm
FRDM-IMX91 BSP changes:
  • U-boot: Add basic support for FRDM-IMX91
  • Kernel: Add basic support for FRDM-IMX91 and add support for kinds of accessories
  • FRDM-IMX91 Yocto layer: Add Yocto layer for FRDM-IMX91 and integrate u-boot/kernel patches
FRDM-IMX91 accessories and corresponding dtb:
  • 5 inch Tianma LCD: imx91-11x11-frdm-tianma-wvga-panel.dtb
  • RPI-CAM-INTB: imx91-11x11-frdm-mt9m114.dtb
  • MX91AUD-HAT or MX91AUD-HAT + 8MIC-RPI-MX8: imx91-11x11-frdm-aud-hat.dtb
  • 8MIC-RPI-MX8: imx91-11x11-frdm-8mic.dtb
  • 2LL M.2 Module: imx91-11x11-frdm.dtb
Build FRDM-IMX91 Yocto Image:
  • Download i.MX SW 2024 Q3 Release:
$ repo init -uhttps://github.com/nxp-imx/imx-manifest-b imx-linux-scarthgap -m imx-6.6.36-2.1.0.xml
$ repo sync
  • Integrate meta-imx-frdm layer into Yocto code base:
$ cd ${MY_YOCTO}/sources
$ git clone https://github.com/nxp-imx-support/meta-imx-frdm.git
  • Yocto Project Setup:
$ cd ${MY_YOCTO}
$ MACHINE=imx91frdm DISTRO=fsl-imx-xwayland source sources/meta-imx-frdm/tools/imx-frdm-setup.sh -b frdm-imx91
  • Build images:
$ bitbake imx-image-full
  • Flashing SD card image using dd:
$ zstdcat imx-image-full-imx91frdm.rootfs.wic.zst | sudo dd of=/dev/sdx bs=1M && sync
  • Or using uuu to burn image to SD card:
$ uuu -b sd_all imx-image-full-imx91frdm.rootfs.wic.zst
FRDM-IMX91 Matter Support
Based on i.MX Matter 2024 Q3
To include Matter support, please follow below steps to include Matter layer into Yocto build.
  • Download i.MX SW 2024 Q3 BSP Release:
$ repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-scarthgap -m imx-6.6.36-2.1.0.xml
$ repo sync
  • Download i.MX Matter Yocto layer:
$ cd ${MY_YOCTO}/sources/meta-nxp-connectivity
$ git remote update
$ git checkout imx_matter_2024_q3
$ cd ${MY_YOCTO}
$ MACHINE=imx91frdm-iwxxx-matter DISTRO=fsl-imx-xwayland source sources/meta-imx-frdm/tools/imx-frdm-matter-setup.sh bld-xwayland-imx91
  • Build images:
$ bitbake imx-image-multimedia
FRDM-IMX91 Debian Release
FRDM-IMX91 has support for Debian 12 OS. i.MX Debian Linux SDK distribution is a combination of NXP-provided kernel and boot loaders with a Debian distro user-space image, which includes:
  • Debian-based rootfs
    1. Debian Base (basic packages)
    2. Debian Server (more packages without GUI Desktop)
    3. Debian Desktop (with GNOME GUI Desktop)
  • Linux kernel
  • BSP components
  • various applications (graphics, multimedia, networking, connectivity, security, and AI/ML)
For more details of NXP Debian Linux SDK Distribution, please check NXP Debian Linux SDK Distribution for i.MX and Layerscape.
Quick Start with Debian:
To create an SD card with Debian for FRDM-IMX91, please follow below steps.
  • Download flex-installer on the Linux host
$ wget http://www.nxp.com/lgfiles/sdk/lsdk2412/flex-installer
$ chmod +x flex-installer
$ sudo mv flex-installer /usr/bin
  • Plug the SD card into the Linux host and install the images as below
# format SD card
$ flex-installer -i pf -d /dev/sdb
# automatically download and install images into SD card
$ flex-installer -i auto -d /dev/mmcblk1 -m imx91frdm
  • Plug the SD card into the FRDM-IMX91 board and install the extra packages as below
        1. Setup Ethernet network interface by DHCP or setting it manually
$ dhclient -i end0
        2. Set correct system time, for example
$ date -s "22 Nov 2024 09:00:00"
        3. Install extra packages for GNOME GUI Desktop version
$ debian-post-install-pkg desktop
        4. Or install extra packages for Server version without GUI Desktop
$ debian-post-install-pkg server
        5. After finishing the installation, run the reboot command to boot up the Debian Desktop/Server system
 Building Debian Images with Flexbuild:
To build Debian image with Flexbuild for FRDM-IMX91, please follow below steps.
  • Set up the build environment
$ git clone https://github.com/nxp/flexbuild
$ cd flexbuild && source setup.env
#Continue to run commands below in case you need to build in Docker due to lack of Ubuntu 22.04 or Debian 12 host
$ bld docker
$ source setup.env
  • Build image with Flexbuild
$ bld -m imx91frdm
  • Flexbuild usage:
    To build individual part of the image, please check below command list for Flexbuild usage
$ bld uboot -m imx91frdm (compile u-boot image for imx91frdm)
$ bld linux (compile linux kernel for all arm64 i.MX machines)
$ bld bsp -m imx91frdm (generate BSP firmware)
$ bld boot (generate boot partition tarball including kernel, dtb, modules, distro bootscript for iMX machines)
$ bld multimedia (build multimedia components for i.MX platforms)
$ bld rfs -r debian:server (generate Debian server rootfs)
$ bld apps -r debian:server (compile apps against runtime dependencies of Debian server RootFS)
$ bld merge-apps -r debian:server (merge iMX-specific apps into target Debian server RootFS)
$ bld packrfs -r debian:server (pack and compress target debian server rootfs)
Related Documentation
FRDM-IMX91 Documents:
More information about i.MX productions can be found at(http://www.nxp.com/imxlinux)
Debian documents at http://www.nxp.com/nxpdebian
标签 (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-2056104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-IMX91%E8%BD%AF%E4%BB%B6%E5%8F%91%E5%B8%83%E4%BB%8B%E7%BB%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3Ei.MX%20FRDM%20%E5%BC%80%E5%8F%91%20(FRDM)%20%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%E5%8C%85%E5%90%AB%E9%A2%84%E6%9E%84%E5%BB%BA%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%81%E6%96%87%E6%A1%A3%E5%92%8C%E7%94%A8%E4%BA%8E%20FRDM-IMX%20%E6%9D%BF%E7%9A%84%20i.MX%20FRDM%20Yocto%20%E5%B1%82%E3%80%82%E5%AE%83%E8%BF%98%E5%8C%85%E6%8B%AC%E5%AF%B9%20Matter%20%E5%92%8C%20Debian%20%E7%89%88%E6%9C%AC%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E6%9C%AC%E6%96%87%E5%B0%86%E5%AF%B9FRDM-IMX91%E8%BD%AF%E4%BB%B6%E5%8F%91%E5%B8%83%E8%BF%9B%E8%A1%8C%E7%AE%80%E5%8D%95%E4%BB%8B%E7%BB%8D%E3%80%82%E6%AC%B2%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E6%9F%A5%E7%9C%8B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10195%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%20FRDM%20%E8%BD%AF%E4%BB%B6%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%0A%3CDIV%20class%3D%22lia-message-template-content-zone%22%3E%0A%3CH3%20id%3D%22toc-hId-1945221399%22%20id%3D%22toc-hId-2005162035%22%3EFRDM-IMX91%20Yocto%20BSP%E5%8F%91%E5%B8%83%3C%2FH3%3E%0A%3CP%3E%E5%9F%BA%E4%BA%8E%20i.MX%20SW%202024%20Q3%20BSP%20%E7%89%88%E6%9C%AC%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ELinux%20kernel%3A%206.6.36_2.1.0%3C%2FLI%3E%0A%3CLI%3Eu-boot%3A%202024.04%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3Ei.MX%20FRDM%20Yocto%20layer%20source%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EFRDM-IMX91%20BSP%E5%8F%98%E5%8C%96%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EU-boot%EF%BC%9A%E6%B7%BB%E5%8A%A0%E5%AF%B9FRDM-IMX91%E7%9A%84%E5%9F%BA%E6%9C%AC%E6%94%AF%E6%8C%81%3C%2FLI%3E%0A%3CLI%3E%E5%86%85%E6%A0%B8%EF%BC%9A%E5%A2%9E%E5%8A%A0%E5%AF%B9FRDM-IMX91%E7%9A%84%E5%9F%BA%E6%9C%AC%E6%94%AF%E6%8C%81%EF%BC%8C%E5%B9%B6%E5%A2%9E%E5%8A%A0%E5%AF%B9%E5%90%84%E7%A7%8D%E9%85%8D%E4%BB%B6%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FLI%3E%0A%3CLI%3EFRDM-IMX91%20Yocto%20%E5%B1%82%EF%BC%9A%E4%B8%BA%20FRDM-IMX91%20%E6%B7%BB%E5%8A%A0%20Yocto%20%E5%B1%82%E5%B9%B6%E9%9B%86%E6%88%90%20u-boot%2F%E5%86%85%E6%A0%B8%E8%A1%A5%E4%B8%81%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSTRONG%3EFRDM-IMX91%E9%85%8D%E4%BB%B6%E5%8F%8A%E5%AF%B9%E5%BA%94dtb%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E5%20inch%20Tianma%20LCD%3A%20%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%3CEM%3Eimx91-11x11-frdm-tianma-wvga-panel.dtb%3C%2FEM%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3ERPI-CAM-INTB%3A%20%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%3CEM%3Eimx91-11x11-frdm-mt9m114.dtb%3C%2FEM%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3EMX91AUD-HAT%20or%20MX91AUD-HAT%20%2B%208MIC-RPI-MX8%3A%20%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%3CEM%3Eimx91-11x11-frdm-aud-hat.dtb%3C%2FEM%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E8MIC-RPI-MX8%3A%20%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%3CEM%3Eimx91-11x11-frdm-8mic.dtb%3C%2FEM%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E2LL%20M.2%20Module%3A%26nbsp%3B%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%3CEM%3E%3CSPAN%3Eimx91-11x11-frdm.dtb%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSTRONG%3E%3CSPAN%3E%E6%9E%84%E5%BB%BAFRDM-IMX91%20Yocto%E5%9B%BE%E5%83%8F%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E4%B8%8B%E8%BD%BD%20i.MX%20SW%202024%20Q3%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20repo%20init%20-u%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%3C%2FA%3E-b%20imx-linux-scarthgap%20-m%20imx-6.6.36-2.1.0.xml%3C%2FP%3E%0A%3CP%3E%24%20repo%20sync%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%E5%B0%86%20meta-imx-frdm%20%E5%B1%82%E9%9B%86%E6%88%90%E5%88%B0%20Yocto%20%E4%BB%A3%E7%A0%81%E5%BA%93%E4%B8%AD%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cd%20%24%7BMY_YOCTO%7D%2Fsources%3C%2FP%3E%0A%3CP%3E%24%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm.git%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm.git%3C%2FA%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3EYocto%20%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%24%20cd%20%24%7BMY_YOCTO%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%24%20MACHINE%3Dimx91frdm%20DISTRO%3Dfsl-imx-xwayland%20%E6%BA%90%E6%BA%90%2Fmeta-imx-frdm%2Ftools%2Fimx-frdm-setup.sh%20-b%20frdm-imx91%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%E6%9E%84%E5%BB%BA%E9%95%9C%E5%83%8F%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%20imx-image-full%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%E4%BD%BF%E7%94%A8%20dd%20%E5%88%B7%E6%96%B0%20SD%20%E5%8D%A1%E6%98%A0%E5%83%8F%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20zstdcat%20imx-image-full-imx91frdm.rootfs.wic.zst%20%7C%20sudo%20dd%20of%3D%2Fdev%2Fsdx%20bs%3D1M%20%26amp%3B%26amp%3B%20sync%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%E6%88%96%E8%80%85%E4%BD%BF%E7%94%A8%20uuu%20%E5%B0%86%E6%98%A0%E5%83%8F%E5%88%BB%E5%BD%95%E5%88%B0%20SD%20%E5%8D%A1%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20uuu%20-b%20sd_all%20imx-%E5%9B%BE%E5%83%8F-%E5%85%A8-imx91frdm.rootfs.wic.zst%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH3%20id%3D%22toc-hId-137766936%22%20id%3D%22toc-hId-197707572%22%3EFRDM-IMX91%20Matter%20%E6%94%AF%E6%8C%81%3C%2FH3%3E%0A%3CP%3E%E5%9F%BA%E4%BA%8E%20i.MX%20Matter%202024%20Q3%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E8%A6%81%E5%8C%85%E5%90%AB%20Matter%20%E6%94%AF%E6%8C%81%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E5%B0%86%20Matter%20%E5%B1%82%E5%8C%85%E5%90%AB%E5%88%B0%20Yocto%20%E6%9E%84%E5%BB%BA%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E4%B8%8B%E8%BD%BD%20i.MX%20SW%202024%20Q3%20BSP%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3CBLOCKQUOTE%3E%0A%3CDIV%20class%3D%22lia-message-template-content-zone%22%3E%3CSPAN%3E%24%20repo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%3C%2FA%3E%20-b%20imx-linux-scarthgap%20-m%20imx-6.6.36-2.1.0.xml%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-template-content-zone%22%3E%3CSPAN%3E%24%20repo%20sync%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%20class%3D%22lia-message-template-content-zone%22%3E%E4%B8%8B%E8%BD%BD%20i.MX%20Matter%20Yocto%20%E5%B1%82%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%24%20cd%20%24%7BMY_YOCTO%7D%20%2Fsources%2Fmeta-nxp-connectivity%3CBR%20%2F%3E%20%24%20git%20%E8%BF%9C%E7%A8%8B%E6%9B%B4%E6%96%B0%3CBR%20%2F%3E%24%20git%20checkout%20imx_matter_2024_q3%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3E%E5%B0%86%20meta-imx-frdm%20%E5%B1%82%E9%9B%86%E6%88%90%E5%88%B0%20Yocto%20%E4%BB%A3%E7%A0%81%E5%BA%93%E4%B8%AD%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%24%20cd%20%24%7BMY_YOCTO%7D%2Fsources%3CBR%20%2F%3E%24%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm.git%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-frdm.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3EYocto%20%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%24%20cd%20%24%7BMY_YOCTO%7D%3CBR%20%2F%3E%20%24%20MACHINE%3Dimx91frdm-iwxxx-matter%20DISTRO%3Dfsl-imx-xwayland%20%E6%BA%90%E6%BA%90%2Fmeta-imx-frdm%2Ftools%2Fimx-frdm-matter-setup.sh%20bld-xwayland-imx91%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3E%E6%9E%84%E5%BB%BA%E9%95%9C%E5%83%8F%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%24%20bitbake%20imx-image-multimedia%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH3%20id%3D%22toc-hId--1669687527%22%20id%3D%22toc-hId--1609746891%22%3E%3CSPAN%3EFRDM-IMX91%20Debian%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3EFRDM-IMX91%20%E6%94%AF%E6%8C%81%20Debian%2012%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E3%80%82i.MX%20Debian%20Linux%20SDK%20%E5%8F%91%E8%A1%8C%E7%89%88%E6%98%AF%20NXP%20%E6%8F%90%E4%BE%9B%E7%9A%84%E5%86%85%E6%A0%B8%E5%92%8C%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B8%8E%20Debian%20%E5%8F%91%E8%A1%8C%E7%89%88%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E6%98%A0%E5%83%8F%E7%9A%84%E7%BB%84%E5%90%88%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E6%8B%AC%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%9F%BA%E4%BA%8E%20Debian%20%E7%9A%84%20rootfs%3CBR%20%2F%3E%0A%3COL%3E%0A%3CLI%3EDebian%20%E5%9F%BA%E7%A1%80%E7%89%88%EF%BC%88%E5%9F%BA%E7%A1%80%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%89%3C%2FLI%3E%0A%3CLI%3EDebian%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%89%88%EF%BC%88%E6%9B%B4%E5%A4%9A%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%8C%E6%97%A0%E5%9B%BE%E5%BD%A2%E6%A1%8C%E9%9D%A2%EF%BC%89%3C%2FLI%3E%0A%3CLI%3EDebian%20%E6%A1%8C%E9%9D%A2%E7%89%88%EF%BC%88%E5%B8%A6%20GNOME%20%E5%9B%BE%E5%BD%A2%E7%95%8C%E9%9D%A2%EF%BC%89%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FLI%3E%0A%3CLI%3ELinux%20kernel%3C%2FLI%3E%0A%3CLI%3EBSP%20%E7%BB%84%E4%BB%B6%3C%2FLI%3E%0A%3CLI%3E%E5%90%84%E7%A7%8D%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E5%9B%BE%E5%BD%A2%E3%80%81%E5%A4%9A%E5%AA%92%E4%BD%93%E3%80%81%E7%BD%91%E7%BB%9C%E3%80%81%E8%BF%9E%E6%8E%A5%E3%80%81%E5%AE%89%E5%85%A8%E5%92%8C%20AI%2FML%EF%BC%89%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E6%9C%89%E5%85%B3%20NXP%20Debian%20Linux%20SDK%20%E5%8F%91%E8%A1%8C%E7%89%88%E7%9A%84%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E6%9F%A5%E7%9C%8B%E9%80%82%E7%94%A8%E4%BA%8E%20i.MX%20%E5%92%8C%20Layerscape%20%E7%9A%84%20NXP%20Debian%20Linux%20SDK%20%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EDebian%20%E5%BF%AB%E9%80%9F%E5%85%A5%E9%97%A8%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E4%BD%BF%E7%94%A8%20Debian%20%E4%B8%BA%20FRDM-IMX91%20%E5%88%9B%E5%BB%BA%20SD%20%E5%8D%A1%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%9C%A8%20Linux%20%E4%B8%BB%E6%9C%BA%E4%B8%8A%E4%B8%8B%E8%BD%BD%20flex-installer%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20wget%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fsdk%2Flsdk2412%2Fflex-installer%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fsdk%2Flsdk2412%2Fflex-installer%3C%2FA%3E%3CBR%20%2F%3E%24%20chmod%20%2Bx%20flex-installer%3CBR%20%2F%3E%20%24%20sudo%20mv%20flex-installer%20%2Fusr%2Fbin%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%E5%B0%86%20SD%20%E5%8D%A1%E6%8F%92%E5%85%A5%20Linux%20%E4%B8%BB%E6%9C%BA%E5%B9%B6%E6%8C%89%E5%A6%82%E4%B8%8B%E6%96%B9%E5%BC%8F%E5%AE%89%E8%A3%85%E6%98%A0%E5%83%8F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%23%20%E6%A0%BC%E5%BC%8F%E5%8C%96%20SD%20%E5%8D%A1%3CBR%20%2F%3E%24%20flex-installer%20-i%20pf%20-d%20%2Fdev%2Fsdb%3CBR%20%2F%3E%20%23%20%E8%87%AA%E5%8A%A8%E4%B8%8B%E8%BD%BD%E5%B9%B6%E5%AE%89%E8%A3%85%E5%9B%BE%E5%83%8F%E5%88%B0%20SD%20%E5%8D%A1%3CBR%20%2F%3E%24%20flex-installer%20-i%20auto%20-d%20%2Fdev%2Fmmcblk1%20-m%20imx91frdm%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%20class%3D%22lia-list-style-type-disc%22%3E%0A%3CLI%3E%E5%B0%86%20SD%20%E5%8D%A1%E6%8F%92%E5%85%A5%20FRDM-IMX91%20%E6%9D%BF%E5%B9%B6%E5%AE%89%E8%A3%85%E4%BB%A5%E4%B8%8B%E9%99%84%E5%8A%A0%E8%BD%AF%E4%BB%B6%E5%8C%85%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E1.%E9%80%9A%E8%BF%87%20DHCP%20%E8%AE%BE%E7%BD%AE%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3%E6%88%96%E6%89%8B%E5%8A%A8%E8%AE%BE%E7%BD%AE%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20dhclient%20-i%20end0%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E2.%E8%AE%BE%E7%BD%AE%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%97%B4%EF%BC%8C%E4%BE%8B%E5%A6%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20%E6%97%A5%E6%9C%9F%20-s%20%222024%20%E5%B9%B4%2011%20%E6%9C%88%2022%20%E6%97%A5%2009%3A00%3A00%22%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E3.%E4%B8%BA%20GNOME%20GUI%20%E6%A1%8C%E9%9D%A2%E7%89%88%E6%9C%AC%E5%AE%89%E8%A3%85%E9%A2%9D%E5%A4%96%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20debian-post-install-pkg%20%E6%A1%8C%E9%9D%A2%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E4.%E6%88%96%E8%80%85%E4%B8%BA%E6%B2%A1%E6%9C%89%20GUI%20%E6%A1%8C%E9%9D%A2%E7%9A%84%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%89%88%E6%9C%AC%E5%AE%89%E8%A3%85%E9%A2%9D%E5%A4%96%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20debian-post-install-pkg%20%E6%9C%8D%E5%8A%A1%E5%99%A8%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E5.%E5%AE%89%E8%A3%85%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E8%BF%90%E8%A1%8Creboot%E5%91%BD%E4%BB%A4%E5%90%AF%E5%8A%A8Debian%20Desktop%2FServer%E7%B3%BB%E7%BB%9F%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%20Flexbuild%20%E6%9E%84%E5%BB%BA%20Debian%20%E9%95%9C%E5%83%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E4%BD%BF%E7%94%A8%20Flexbuild%20%E4%B8%BA%20FRDM-IMX91%20%E6%9E%84%E5%BB%BA%20Debian%20%E6%98%A0%E5%83%8F%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E8%AE%BE%E7%BD%AE%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp%2Fflexbuild%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp%2Fflexbuild%3C%2FA%3E%3CBR%20%2F%3E%24%20cd%20flexbuild%20%26amp%3B%26amp%3B%20%E6%BA%90%E8%AE%BE%E7%BD%AE.env%3CBR%20%2F%3E%23%E5%A6%82%E6%9E%9C%E7%94%B1%E4%BA%8E%E7%BC%BA%E5%B0%91%20Ubuntu%2022.04%20%E6%88%96%20Debian%2012%20%E4%B8%BB%E6%9C%BA%E8%80%8C%E9%9C%80%E8%A6%81%E5%9C%A8%20Docker%20%E4%B8%AD%E6%9E%84%E5%BB%BA%EF%BC%8C%E8%AF%B7%E7%BB%A7%E7%BB%AD%E8%BF%90%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%3CBR%20%2F%3E%24%20bld%20docker%3CBR%20%2F%3E%20%24%20%E6%BA%90%E8%AE%BE%E7%BD%AE.env%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%E4%BD%BF%E7%94%A8%20Flexbuild%20%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bld%20-m%20imx91frdm%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3EFlexbuild%E7%94%A8%E6%B3%95%EF%BC%9A%3CBR%20%2F%3E%E8%A6%81%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%E7%9A%84%E5%8D%95%E4%B8%AA%E9%83%A8%E5%88%86%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%91%BD%E4%BB%A4%E5%88%97%E8%A1%A8%E4%BB%A5%E4%BA%86%E8%A7%A3%20Flexbuild%20%E7%94%A8%E6%B3%95%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bld%20uboot%20-m%20imx91frdm%20%EF%BC%88%E4%B8%BA%20imx91frdm%20%E7%BC%96%E8%AF%91%20u-boot%20%E6%98%A0%E5%83%8F%EF%BC%89%3CBR%20%2F%3E%20%24%20bld%20linux%EF%BC%88%E4%B8%BA%E6%89%80%E6%9C%89%20arm64%20i.MX%20%E6%9C%BA%E5%99%A8%E7%BC%96%E8%AF%91%20linux%20%E5%86%85%E6%A0%B8%EF%BC%89%3CBR%20%2F%3E%20%24%20bld%20bsp%20-m%20imx91frdm%EF%BC%88%E7%94%9F%E6%88%90BSP%E5%9B%BA%E4%BB%B6%EF%BC%89%3CBR%20%2F%3E%20%24%20bld%20boot%EF%BC%88%E7%94%9F%E6%88%90%E5%90%AF%E5%8A%A8%E5%88%86%E5%8C%BA%20tarball%EF%BC%8C%E5%8C%85%E6%8B%AC%E5%86%85%E6%A0%B8%E3%80%81dtb%E3%80%81%E6%A8%A1%E5%9D%97%E3%80%81iMX%20%E6%9C%BA%E5%99%A8%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%E5%90%AF%E5%8A%A8%E8%84%9A%E6%9C%AC%EF%BC%89%3CBR%20%2F%3E%20%24%20bld%20multimedia%EF%BC%88%E4%B8%BA%20i.MX%20%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BA%E5%A4%9A%E5%AA%92%E4%BD%93%E7%BB%84%E4%BB%B6%EF%BC%89%3CBR%20%2F%3E%20%24%20bld%20rfs%20-r%20debian%3Aserver%20%EF%BC%88%E7%94%9F%E6%88%90%20Debian%20%E6%9C%8D%E5%8A%A1%E5%99%A8%20rootfs%EF%BC%89%3CBR%20%2F%3E%20%24%20bld%20apps%20-r%20debian%3Aserver%20%EF%BC%88%E9%92%88%E5%AF%B9%20Debian%20%E6%9C%8D%E5%8A%A1%E5%99%A8%20RootFS%20%E7%9A%84%E8%BF%90%E8%A1%8C%E6%97%B6%E4%BE%9D%E8%B5%96%E9%A1%B9%E7%BC%96%E8%AF%91%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%3CBR%20%2F%3E%20%24%20bld%20merge-apps%20-r%20debian%3Aserver%EF%BC%88%E5%B0%86%20iMX%20%E7%89%B9%E5%AE%9A%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%88%E5%B9%B6%E5%88%B0%E7%9B%AE%E6%A0%87%20Debian%20%E6%9C%8D%E5%8A%A1%E5%99%A8%20RootFS%EF%BC%89%3CBR%20%2F%3E%20%24%20bld%20packrfs%20-r%20debian%3Aserver%20%EF%BC%88%E6%89%93%E5%8C%85%E5%B9%B6%E5%8E%8B%E7%BC%A9%E7%9B%AE%E6%A0%87%20debian%20%E6%9C%8D%E5%8A%A1%E5%99%A8%20rootfs%EF%BC%89%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH3%20id%3D%22toc-hId-817825306%22%20id%3D%22toc-hId-877765942%22%3E%E7%9B%B8%E5%85%B3%E6%96%87%E6%A1%A3%3C%2FH3%3E%0A%3CP%3EFRDM-IMX91%E6%96%87%E6%A1%A3%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-frdm-imx91%3AGS-FRDM-IMX91%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFRDM-IMX91%E5%BF%AB%E9%80%9F%E5%85%A5%E9%97%A8%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUM12262%26amp%3Blocation%3Dnull%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFRDM-IMX91%20%E5%BC%80%E5%8F%91%E6%9D%BF%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10195%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%20FRDM%E8%BD%AF%E4%BB%B6%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E6%9B%B4%E5%A4%9A%20i.MX%20%E4%BA%A7%E5%93%81%E4%BF%A1%E6%81%AF%E8%AF%B7%E8%AE%BF%E9%97%AE%20(%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fimxlinux%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fimxlinux%3C%2FA%3E)%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_YOCTO_PROJECT_USERS_GUIDE.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_YOCTO_PROJECT_USERS_GUIDE.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E7%BA%A6%E5%85%8B%E6%89%98%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_YOCTO_PROJECT_USERS_GUIDE.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E9%A1%B9%E7%9B%AE%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_LINUX_USERS_GUIDE.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%20Linux%20User%E2%80%99s%20Guide%E2%80%8B%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Freference-manual%2FIMX_REFERENCE_MANUAL.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%20Linux%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E2%80%8B%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_PORTING_GUIDE.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%20%E7%A7%BB%E6%A4%8D%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EDebian%20%E6%96%87%E6%A1%A3%E4%BD%8D%E4%BA%8E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fnxpdebian%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fnxpdebian%3C%2FA%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CU%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUG10155%2Fpage%2Ftopics%2Foverview.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%20Debian%20Linux%20SDK%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FLI%3E%0A%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2056104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFRDM-IMX91%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EFRDM%20%E5%9F%B9%E8%AE%AD%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎03-11-2025 10:15 AM
更新人:
