Deploy Android14 on FRDM-iMX8MP Lf6.6.36
Customer may want to deploy Android 14 on FRDM-iMX8MP. This doc gives an introduction about how to deploy Android OS14 on FRDM-iMX8MP
Hardware:
FRDM-iMX8MP, Power supply cable, usb cable x2,
Ubuntu PC
Outline:
Follow the below steps:
  • Setup the Android 14 source environment based on LF6.6.36.
  • Apply FRDM-iMX8MP patches in kernel, uboot, mkimage, and device directory.
  • Build the image for FRDM-iMX8MP
  • Flash the image
1. Setup the environment
  • On the Linux PC, set up the Android Source environment according to Section 2- Section 3 from the Android User’s Guide Rev. android-14.0.0_2.1.0 and do not build the image yet.
    $ cd ~ (or any other directory you like)
    $ tar xzvf imx-android-14.0.0_2.1.0.tar.gz
  • To generate the i.MX Android release source code build environment, execute the following commands:
    $ source ~/imx-android-14.0.0_2.1.0/imx_android_setup.sh
  • Prepare the build environment for U-Boot and Linux kernel. This step is mandatory because there is no GCC cross-compile tool chain in the one in AOSP codebase. An approach is provided to use the self-installed GCC cross-compile tool chain for both AArch32 and AArch64.
  • Change to the top-level build directory and set up the environment for building. This only configures the current terminal
    $ cd ${MY_ANDROID}
    $ source build/envsetup.sh
2. Apply FRDM-iMX8MP patches into AOSP
  • Apply the patch in device/nxp, copy all the patches into android_build/device/nxp, and then running the command:
    $ git apply --check 0001-device-nxp-add-FRDM-i.MX8MP-Android14-basic-support.patch
    $ git apply 0001-device-nxp-add-FRDM-i.MX8MP-Android14-basic-support.patch
  • Apply the patches in uboot, copy all the patches into android_build/vendor/nxp-opensource/uboot-imx, and then running the command:
    $ git am *.patch
  • Apply the patches in kernel, copy all the patches into android_build/vendor/nxp-opensource/kernel-imx, and then running the command:
    $ git am *.patch
  • Apply the patch in mkimage, copy all the patches into android_build/vendor/nxp-opensource/ imx-mkimage, and then running the command:
    $ git am *.patch
3. Build the image for FRDM-iMX8MP
  • Execute the Android lunch command:
    $ lunch frdm_8mp-trunk_staging-userdebug
  • Execute the imx-make.sh script to generate the image.
    $ ./imx-make.sh -j4 2>&1 | tee build-log.txt
    NOTE: The following outputs are generated by default in ${MY_ANDROID}/out/target/product/frdm_8mp:
4. Flash the image
The board image files can be flashed into the target board using Universal Update Utility (UUU).
For the UUU binary file, download it from GitHub: uuu release page on GitHub.
To achieve more flexibility, two script files are provided to invoke UUU to automatically flash all Android images.
  • uuu_imx_android_flash.sh for Linux OS
  • uuu_imx_android_flash.bat for Windows OS
For this release, these two scripts are validated on UUU 1.5.179 version. Download the corresponding version from GitHub:
  • For Linux OS, download the file named uuu.
  • For Windows OS, download the file named uuu.exe.
Perform the following steps to download the board images:
  • Download the UUU binary file from GitHub as described before. Install UUU into a directory contained by the system environment variable of "PATH".
  • Make the board enter serial download mode. Change the board's SW5 (boot mode) to 0001 (from 1-4 bit) to enter serial download mode.
  • Power on the board. Use the USB cable to connect the USB 3.0 dual-role port (with silkprint "PORT1") on the board to your host PC.
  • On the Linux system, open the shell terminal. For example, you can execute a command as follows:
    $ sudo ./uuu_imx_android_flash.sh -f imx8mp -p frdm -a -e
  • On the Windows system, open the command-line interface in administrator mode. The corresponding command is as follows:
    $ uuu_imx_android_flash.bat -f imx8mp -p frdm -a -e
NOTE: If you want to change the dtb, you can add -d dtb_feature. Also, you can check all the info by using the command: uuu_imx_android_flash.bat
Power off the board and Change the board's SW5 (boot mode) to 0010 (from 1-4 bit) to enter emmc boot mode
No ratings
Version history
Last update:
‎08-27-2025 11:05 AM
Updated by:
