imx6ull IAR Verify error at address 0x8000200C
Levear
下载到qspi时的问题见imx 6ull mfgtool download qspi - NXP Community
IMx6uLL在线调试时又出现以下内容,无法调试,log如下
Thu Jun 13, 2024 16:57:20: IAR Embedded Workbench 7.80.4 (armproc.dll)
Thu Jun 13, 2024 16:57:21: Device "ARM7" selected.
Thu Jun 13, 2024 16:57:21: JLINK command: ProjectFile = E:\SDK_2.2\boards\evkmcimx6ull\demo_apps\lwip\lwip_udpecho\bm\iar\settings\lwip_udpecho_bm_ddr_debug.jlink, return = 0
Thu Jun 13, 2024 16:57:21: JLINK command: scriptfile = E:\SDK_2.2\boards\evkmcimx6ull\demo_apps\lwip\lwip_udpecho\bm\iar/../ddr_init.jlinkscript, return = 0
Thu Jun 13, 2024 16:57:21: DLL version: V6.12f, compiled Jan 13 2017 16:37:50
Thu Jun 13, 2024 16:57:21: Firmware: J-Link V9 compiled May 7 2021 16:26:12
Thu Jun 13, 2024 16:57:21: JTAG speed is initially set to: 32 kHz
Thu Jun 13, 2024 16:57:21: Initial reset was performed
Thu Jun 13, 2024 16:57:21: Config JTAG Speed to 4000kHz
Thu Jun 13, 2024 16:57:21: TotalIRLen = 13, IRPrint = 0x0101
Thu Jun 13, 2024 16:57:21: Warning: At least one of the connected devices is not JTAG compliant (IEEE Std 1149.1, 7.1.1.d, IR-cells). (NumDevices = 3, NumBitsSet = 2)
Thu Jun 13, 2024 16:57:21: CoreSight AP[0]: 0x04770001, AHB-AP
Thu Jun 13, 2024 16:57:21: CoreSight AP[1]: 0x04770002, APB-AP
Thu Jun 13, 2024 16:57:21: ROMTbl 0 [0]: 00001003, CID: B105900D, PID:04-001BB961 TMC
Thu Jun 13, 2024 16:57:21: ROMTbl 0 [1]: 00002003, CID: B105900D, PID:04-004BB906 ECT / CTI
Thu Jun 13, 2024 16:57:21: ROMTbl 0 [2]: 00003003, CID: B105900D, PID:04-004BB912 TPIU
Thu Jun 13, 2024 16:57:21: ROMTbl 0 [3]: 00004003, CID: B105F00D, PID:04-001BB101
Thu Jun 13, 2024 16:57:21: ROMTbl 0 [4]: 00020003, CID: B105100D, PID:04-000BB4A7 ROM Table
Thu Jun 13, 2024 16:57:21: ROMTbl 1 [0]: 00010003, CID: B105900D, PID:04-005BBC07 Cortex-A7
Thu Jun 13, 2024 16:57:21: Found Cortex-A7 r0p5
Thu Jun 13, 2024 16:57:21: 6 code breakpoints, 4 data breakpoints
Thu Jun 13, 2024 16:57:21: Debug architecture ARMv7.1
Thu Jun 13, 2024 16:57:21: Data endian: little
Thu Jun 13, 2024 16:57:21: Main ID register: 0x410FC075
Thu Jun 13, 2024 16:57:21: I-Cache L1: 32 KB, 512 Sets, 32 Bytes/Line, 2-Way
Thu Jun 13, 2024 16:57:21: D-Cache L1: 32 KB, 128 Sets, 64 Bytes/Line, 4-Way
Thu Jun 13, 2024 16:57:21: Unified-Cache L2: 128 KB, 256 Sets, 64 Bytes/Line, 8-Way
Thu Jun 13, 2024 16:57:21: System control register:
Thu Jun 13, 2024 16:57:21: Instruction endian: little
Thu Jun 13, 2024 16:57:21: Level-1 instruction cache disabled
Thu Jun 13, 2024 16:57:21: Level-1 data cache disabled
Thu Jun 13, 2024 16:57:21: MMU disabled
Thu Jun 13, 2024 16:57:21: Branch prediction enabled
Thu Jun 13, 2024 16:57:21: Enabling i.MX6ULL DDR3L
Thu Jun 13, 2024 16:57:21: Clock Init Done
Thu Jun 13, 2024 16:57:21: DDR Init Done
Thu Jun 13, 2024 16:57:21: Found 3 JTAG devices, Total IRLen = 13:
Thu Jun 13, 2024 16:57:21: #0 Id: 0x5BA00477, IRLen: 4, IRPrint: 0x1 CoreSight JTAG-DP
Thu Jun 13, 2024 16:57:21: #1 Id: 0x00000001
Thu Jun 13, 2024 16:57:21: #2 Id: 0x088C101D
Thu Jun 13, 2024 16:57:24: 67951 bytes downloaded and verified (26.21 Kbytes/sec)
Thu Jun 13, 2024 16:57:24: Warning:
Verify error at address 0x8000200C, target byte: 0x00, byte in file: 0x18
Verify error at address 0x8000200E, target byte: 0x00, byte in file: 0x9F
Verify error at address 0x80002010, target byte: 0x00, byte in file: 0x18
Verify error at address 0x80002011, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x80002012, target byte: 0x00, byte in file: 0x9F
Verify error at address 0x80002013, target byte: 0x00, byte in file: 0xE5
Verify error at address 0x80002014, target byte: 0x14, byte in file: 0x00
Verify error at address 0x80002015, target byte: 0xF0, byte in file: 0x00
Verify error at address 0x80002016, target byte: 0x9F, byte in file: 0x00
Verify error at address 0x80002017, target byte: 0xE5, byte in file: 0x00
Verify error at address 0x8000201C, target byte: 0x00, byte in file: 0x14
Verify error at address 0x8000201E, target byte: 0x00, byte in file: 0x9F
Verify error at address 0x80002020, target byte: 0xA4, byte in file: 0x10
Verify error at address 0x80002021, target byte: 0x05, byte in file: 0x06
Verify error at address 0x80002024, target byte: 0xA8, byte in file: 0xA4
Verify error at address 0x80002028, target byte: 0xAC, byte in file: 0xA8
Verify error at address 0x8000202C, target byte: 0x00, byte in file: 0xAC
Verify error at address 0x8000202D, target byte: 0x06, byte in file: 0x05
Verify error at address 0x8000202E, target byte: 0x00, byte in file: 0x01
Verify error at address 0x80002030, target byte: 0xB4, byte in file: 0xB0
Verify error at address 0x80002034, target byte: 0x08, byte in file: 0xB4
Verify error at address 0x80002035, target byte: 0x06, byte in file: 0x05
Verify error at address 0x80002038, target byte: 0xFF, byte in file: 0x08
Verify error at address 0x80002039, target byte: 0xFF, byte in file: 0x06
Verify error at address 0x8000203A, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x8000203B, target byte: 0xFF, byte in file: 0x80
Verify error at address 0x80002040, target byte: 0x83, byte in file: 0x2D
Verify error at address 0x80002041, target byte: 0xB0, byte in file: 0xE9
Verify error at address 0x80002042, target byte: 0x04, byte in file: 0xF0
Verify error at address 0x80002043, target byte: 0x00, byte in file: 0x4F
Verify error at address 0x80002044, target byte: 0x0D, byte in file: 0x83
Verify error at address 0x80002045, target byte: 0x00, byte in file: 0xB0
Verify error at address 0x80002046, target byte: 0x60, byte in file: 0x04
Verify error at address 0x80002047, target byte: 0x68, byte in file: 0x00
Verify error at address 0x80002048, target byte: 0xDF, byte in file: 0x0D
Verify error at address 0x80002049, target byte: 0xF8, byte in file: 0x00
Verify error at address 0x8000204A, target byte: 0xF4, byte in file: 0x60
Verify error at address 0x8000204B, target byte: 0x17, byte in file: 0x68
Verify error at address 0x8000204C, target byte: 0x00, byte in file: 0xDF
Verify error at address 0x8000204D, target byte: 0xE9, byte in file: 0xF8
Verify error at address 0x8000204E, target byte: 0x00, byte in file: 0xF4
Verify error at address 0x8000204F, target byte: 0x4F, byte in file: 0x17
Verify error at address 0x80002050, target byte: 0x14, byte in file: 0x08
Verify error at address 0x80002051, target byte: 0x28, byte in file: 0x60
Verify error at address 0x80002052, target byte: 0xC0, byte in file: 0x60
Verify error at address 0x80002053, target byte: 0xF2, byte in file: 0x89
Verify error at address 0x80002054, target byte: 0x00, byte in file: 0x14
Verify error at address 0x80002055, target byte: 0x83, byte in file: 0x28
Verify error at address 0x80002056, target byte: 0xDF, byte in file: 0xC0
Verify error at address 0x80002057, target byte: 0xF8, byte in file: 0xF2
Verify error at address 0x80002058, target byte: 0xEC, byte in file: 0x00
Verify error at address 0x80002059, target byte: 0x07, byte in file: 0x83
Verify error at address 0x8000205A, target byte: 0x01, byte in file: 0xDF
Verify error at address 0x8000205B, target byte: 0x68, byte in file: 0xF8
Verify error at address 0x8000205C, target byte: 0x00, byte in file: 0xEC
Verify error at address 0x8000205D, target byte: 0x60, byte in file: 0x07
Verify error at address 0x8000205E, target byte: 0x00, byte in file: 0x01
Verify error at address 0x8000205F, target byte: 0x89, byte in file: 0x68
Verify error at address 0x80002060, target byte: 0x40, byte in file: 0xDF
Verify error at address 0x80002061, target byte: 0x69, byte in file: 0xF8
Verify error at address 0x80002062, target byte: 0x01, byte in file: 0xE4
Verify error at address 0x80002063, target byte: 0xF0, byte in file: 0x07
Verify error at address 0x80002064, target byte: 0x21, byte in file: 0x40
Verify error at address 0x80002065, target byte: 0xFB, byte in file: 0x69
Verify error at address 0x80002066, target byte: 0x00, byte in file: 0x01
Verify error at address 0x80002067, target byte: 0x28, byte in file: 0xF0
Verify error at address 0x80002068, target byte: 0x06, byte in file: 0x21
Verify error at address 0x80002069, target byte: 0xD1, byte in file: 0xFB
Verify error at address 0x8000206A, target byte: 0xDF, byte in file: 0x00
Verify error at address 0x8000206B, target byte: 0xF8, byte in file: 0x28
Verify error at address 0x8000206C, target byte: 0x00, byte in file: 0x06
Verify error at address 0x8000206D, target byte: 0xF8, byte in file: 0xD1
Verify error at address 0x8000206E, target byte: 0x00, byte in file: 0xDF
Verify error at address 0x8000206F, target byte: 0x07, byte in file: 0xF8
Verify error at address 0x80002070, target byte: 0x10, byte in file: 0xD8
Verify error at address 0x80002071, target byte: 0xF0, byte in file: 0x07
Verify error at address 0x80002072, target byte: 0xF0, byte in file: 0x00
Verify error at address 0x80002073, target byte: 0x00, byte in file: 0x7D
Verify error at address 0x80002074, target byte: 0xE0, byte in file: 0x10
Verify error at address 0x80002075, target byte: 0x28, byte in file: 0xF0
Verify error at address 0x80002076, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x80002077, target byte: 0xD1, byte in file: 0x00
Verify error at address 0x80002078, target byte: 0xED, byte in file: 0xE0
Verify error at address 0x80002079, target byte: 0xE2, byte in file: 0x28
Verify error at address 0x8000207A, target byte: 0xDF, byte in file: 0x00
Verify error at address 0x8000207B, target byte: 0xF8, byte in file: 0xD1
Verify error at address 0x8000207C, target byte: 0x00, byte in file: 0xED
Verify error at address 0x8000207D, target byte: 0x07, byte in file: 0xE2
Verify error at address 0x8000207E, target byte: 0x00, byte in file: 0xDF
Verify error at address 0x8000207F, target byte: 0x7D, byte in file: 0xF8
Verify error at address 0x80002080, target byte: 0xDF, byte in file: 0x5C
Verify error at address 0x80002081, target byte: 0xF8, byte in file: 0x0D
Verify error at address 0x80002082, target byte: 0x58, byte in file: 0x00
Verify error at address 0x80002083, target byte: 0x3D, byte in file: 0x90
Verify error at address 0x80002084, target byte: 0x22, byte in file: 0xDF
Verify error at address 0x80002085, target byte: 0x89, byte in file: 0xF8
Verify error at address 0x80002086, target byte: 0x06, byte in file: 0x58
Verify error at address 0x80002087, target byte: 0x21, byte in file: 0x3D
Verify error at address 0x80002088, target byte: 0x20, byte in file: 0x22
Verify error at address 0x80002089, target byte: 0x00, byte in file: 0x89
Verify error at address 0x8000208A, target byte: 0x01, byte in file: 0x06
Verify error at address 0x8000208B, target byte: 0xF0, byte in file: 0x21
Verify error at address 0x8000208C, target byte: 0x00, byte in file: 0x20
Verify error at address 0x8000208D, target byte: 0x0D, byte in file: 0x00
Verify error at address 0x8000208E, target byte: 0x00, byte in file: 0x01
Verify error at address 0x8000208F, target byte: 0x90, byte in file: 0xF0
Verify error at address 0x80002090, target byte: 0x00, byte in file: 0xE4
Verify error at address 0x80002091, target byte: 0x28, byte in file: 0xFB
Verify error at address 0x80002092, target byte: 0x40, byte in file: 0x80
Verify error at address 0x80002093, target byte: 0xF0, byte in file: 0xB2
Verify error at address 0x80002094, target byte: 0xE0, byte in file: 0x00
Verify error at address 0x80002095, target byte: 0x82, byte in file: 0x28
Verify error at address 0x80002096, target byte: 0xDF, byte in file: 0x40
Verify error at address 0x80002097, target byte: 0xF8, byte in file: 0xF0
Verify error at address 0x80002098, target byte: 0xA8, byte in file: 0xE0
Verify error at address 0x80002099, target byte: 0x07, byte in file: 0x82
Verify error at address 0x8000209A, target byte: 0x00, byte in file: 0xDF
Verify error at address 0x8000209B, target byte: 0x68, byte in file: 0xF8
Verify error at address 0x8000209C, target byte: 0x00, byte in file: 0xA8
Verify error at address 0x8000209D, target byte: 0xFB, byte in file: 0x07
Verify error at address 0x8000209F, target byte: 0xB2, byte in file: 0x68
Verify error at address 0x800020A0, target byte: 0x2D, byte in file: 0x80
Verify error at address 0x800020A1, target byte: 0xFC, byte in file: 0x89
Verify error at address 0x800020A2, target byte: 0x80, byte in file: 0x01
Verify error at address 0x800020A3, target byte: 0xB2, byte in file: 0xF0
Verify error at address 0x800020A4, target byte: 0x00, byte in file: 0x2D
Verify error at address 0x800020A5, target byte: 0x0B, byte in file: 0xFC
Verify error at address 0x800020A6, target byte: 0xC0, byte in file: 0x80
Verify error at address 0x800020A8, target byte: 0x80, byte in file: 0x00
Verify error at address 0x800020A9, target byte: 0x00, byte in file: 0x0B
Verify error at address 0x800020AA, target byte: 0x81, byte in file: 0xC0
Verify error at address 0x800020AB, target byte: 0x46, byte in file: 0xB2
Verify error at address 0x800020AC, target byte: 0x00, byte in file: 0x80
Verify error at address 0x800020AD, target byte: 0x89, byte in file: 0x00
Verify error at address 0x800020AE, target byte: 0x00, byte in file: 0x81
Verify error at address 0x800020AF, target byte: 0xF0, byte in file: 0x46
Verify error at address 0x800020B0, target byte: 0xB9, byte in file: 0x5F
Verify error at address 0x800020B1, target byte: 0xF1, byte in file: 0xFA
Verify error at address 0x800020B2, target byte: 0x14, byte in file: 0x89
Verify error at address 0x800020B3, target byte: 0x0F, byte in file: 0xF9
Verify error at address 0x800020B4, target byte: 0x05, byte in file: 0xB9
Verify error at address 0x800020B5, target byte: 0xDB, byte in file: 0xF1
Verify error at address 0x800020B6, target byte: 0x20, byte in file: 0x14
Verify error at address 0x800020B7, target byte: 0x89, byte in file: 0x0F
Verify error at address 0x800020B8, target byte: 0x49, byte in file: 0x05
Verify error at address 0x800020B9, target byte: 0x46, byte in file: 0xDB
Verify error at address 0x800020BA, target byte: 0xC9, byte in file: 0x20
Verify error at address 0x800020BB, target byte: 0xB2, byte in file: 0x89
Verify error at address 0x800020BC, target byte: 0x00, byte in file: 0x49
Verify error at address 0x800020BD, target byte: 0xFA, byte in file: 0x46
Verify error at address 0x800020BE, target byte: 0x00, byte in file: 0xC9
Verify error at address 0x800020BF, target byte: 0xF9, byte in file: 0xB2
Verify error at address 0x800020C0, target byte: 0x00, byte in file: 0x89
Verify error at address 0x800020C1, target byte: 0xD2, byte in file: 0xB2
Verify error at address 0x800020C2, target byte: 0xC8, byte in file: 0x88
Verify error at address 0x800020C3, target byte: 0xE2, byte in file: 0x42
Verify error at address 0x800020C4, target byte: 0x5F, byte in file: 0x00
Verify error at address 0x800020C5, target byte: 0xFA, byte in file: 0xD2
Verify error at address 0x800020C6, target byte: 0x89, byte in file: 0xC8
Verify error at address 0x800020C7, target byte: 0xF9, byte in file: 0xE2
Verify error at address 0x800020C8, target byte: 0xB9, byte in file: 0x5F
Verify error at address 0x800020C9, target byte: 0xF1, byte in file: 0xFA
Verify error at address 0x800020CA, target byte: 0x14, byte in file: 0x89
Verify error at address 0x800020CB, target byte: 0x00, byte in file: 0xF9
Verify error at address 0x800020CC, target byte: 0x00, byte in file: 0xB9
Verify error at address 0x800020CD, target byte: 0xB2, byte in file: 0xF1
Verify error at address 0x800020CE, target byte: 0x00, byte in file: 0x14
Verify error at address 0x800020CF, target byte: 0x42, byte in file: 0x00
Verify error at address 0x800020D0, target byte: 0x08, byte in file: 0xDF
Verify error at address 0x800020D1, target byte: 0x80, byte in file: 0xF8
Verify error at address 0x800020D2, target byte: 0x00, byte in file: 0x78
Verify error at address 0x800020D3, target byte: 0x20, byte in file: 0x17
Verify error at address 0x800020D4, target byte: 0xDF, byte in file: 0x08
Verify error at address 0x800020D5, target byte: 0xF8, byte in file: 0x80
Verify error at address 0x800020D6, target byte: 0x74, byte in file: 0x00
Verify error at address 0x800020D7, target byte: 0x17, byte in file: 0x20
Verify error at address 0x800020D8, target byte: 0x08, byte in file: 0xDF
Verify error at address 0x800020D9, target byte: 0x60, byte in file: 0xF8
Verify error at address 0x800020DA, target byte: 0x60, byte in file: 0x74
Verify error at address 0x800020DB, target byte: 0x89, byte in file: 0x17
Verify error at address 0x800020DC, target byte: 0x00, byte in file: 0x08
Verify error at address 0x800020DD, target byte: 0xF8, byte in file: 0x60
Verify error at address 0x800020DE, target byte: 0x00, byte in file: 0x60
Verify error at address 0x800020DF, target byte: 0x17, byte in file: 0x89
Verify error at address 0x800020E0, target byte: 0x89, byte in file: 0x49
Verify error at address 0x800020E1, target byte: 0xB2, byte in file: 0x46
Verify error at address 0x800020E2, target byte: 0x88, byte in file: 0xC9
Verify error at address 0x800020E3, target byte: 0x42, byte in file: 0xB2
Verify error at address 0x800020E4, target byte: 0x0E, byte in file: 0x89
Verify error at address 0x800020E5, target byte: 0xD3, byte in file: 0xB2
Verify error at address 0x800020E6, target byte: 0xDF, byte in file: 0x88
Verify error at address 0x800020E7, target byte: 0xF8, byte in file: 0x42
Verify error at address 0x800020E8, target byte: 0x60, byte in file: 0x0E
Verify error at address 0x800020E9, target byte: 0x07, byte in file: 0xD3
Verify error at address 0x800020EA, target byte: 0x00, byte in file: 0xDF
Verify error at address 0x800020EB, target byte: 0x88, byte in file: 0xF8
Verify error at address 0x800020EC, target byte: 0x00, byte in file: 0x60
Verify error at address 0x800020ED, target byte: 0x46, byte in file: 0x07
Verify error at address 0x800020EF, target byte: 0xB2, byte in file: 0x88
Verify error at address 0x800020F0, target byte: 0x08, byte in file: 0xDF
Verify error at address 0x800020F1, target byte: 0x80, byte in file: 0xF8
Thu Jun 13, 2024 16:57:24: Warning: Too many verify errors, only the first 200 are displayed
Thu Jun 13, 2024 16:57:25: Warning: There were warnings during download, see Log Window
Thu Jun 13, 2024 16:57:25: Loaded debugee: E:\SDK_2.2\boards\evkmcimx6ull\demo_apps\lwip\lwip_udpecho\bm\iar\ddr_debug\lwip_udpecho_bm.out
Thu Jun 13, 2024 16:57:25: Software reset was performed
Thu Jun 13, 2024 16:57:25: Target reset
Thu Jun 13, 2024 16:57:25: There was 1 warning during the initialization of the debugging session.
Levear
已找到原因,内存的问题。
