S32R294 && TEF8102 RsdkRfeInit
1,751件の閲覧回数
binsan123
When I configure TEF8102 and configure FRONTEND 0, when I call API (RsdkRfeInit), an occasional error code is RSDK_TEF810X_DATAPTTRNTESTFAIL, resulting in a power-off failure. Sometimes an exception occurs, sometimes not. What is the most likely reason? Is there any solution?
1,738件の閲覧回数
binsan123
API  glue_CheckTestPattern return false。
pDrvState-> pRfBistBufData sometimes has a value, returns true if it has a value, sometimes has no value, returns false if it has no value, generates an error code, why does it have no value? PRfBistBufData in 0
