S32E integration reference example for bootloader and lighting
ayy24
 I install the integration reference example for S32E while loading it EB tersos it showing various pulgins for the example are not found
installation directory only tersos workspace founded NO S32DS workspace found for both the example provided in the integration refernce install directory while it clearly mention in the manual provided in the installation directory.
I am also attaching the screenshot of those kindly help in this issue.
Vivek_123
I need a source code for Java application(Tool to download User Application to S32K144 when running bootloader) for UART based Bootloader example.
here I share  link  for that.
Link: Re: S32K144 Bootloader Example - NXP Community
Please find the link and check source code for Tool(Java Application) Bootloader interface. If it is Possible Please send the source code.
Thanks in advance
Rutika_Pawar
We are facing the same issue but for Eclipse S32DS IDE.
May I know, why we are not getting platform application for bootloader as you have provided for other version.
Like below image:
Thanks in advance
