Need Help Understanding Snap BSF List Planets
253件の閲覧回数
yisey
Hi everyone,
I recently started playing Battle Star Fantasy and came across the feature where you can manage different worlds and resources. I noticed there’s a specific setup called the “snap bsf list planets,” but I’m a bit confused about how it works.
Can someone explain what the best strategy is for using the snap bsf list planets effectively? Are there certain planets that should always be prioritized, or is it more situational? Any tips on maximizing rewards while using this feature would be really appreciated.
Thanks in advance!
130件の閲覧回数
paulvernoun
Hey! I’ve been playing Battle Star Fantasy for a while now — the snap bsf list planets feature basically helps you organize and switch between your planets faster. The best approach really depends on your play style, but generally, prioritize planets with higher resource yields and shorter production times first.
Also, make sure to balance between resource-heavy planets and defense setups — that way, you don’t lose progress if you get attacked. It’s pretty situational, but once you figure out which planets give the best return for your effort, it becomes super efficient.
