UWB MAX RANGING DISTANCE
1,585 次查看
RG30
Can you please tell me what is the maximum working range I can have with the Trimension  SR150+SR040 devices in  ANCHOR/TAG configuration without losing the signal?
What is recommended range for not losing the signal in direct LOS?
Can I control the range (extend it ) by software configuration/power source?
thank you
Roman
0 回复数
