RDDRONE-BMS772 BMS - missing libcanard library
suvasis
hi,
I recently purchased RDDRONE-BMS772 BMS evaluation board and followed the instructions:
https://github.com/NXPHoverGames/RDDRONE-BMS772
I have installed Windows Subsystem for Linux (Ubuntu) and followed the instructions on Git to setup the toolchain and build the firmware. Setup is fine, however when built to create a binary for the firmware (both Normal and Debug configuration) results in an error reporting a missing libcanard library. The setup and build log is attached for your reference. Please suggest a solution on how to resolve this?
