KIT-HGDRONEK66 different motors
已解决
跳至解决方案
9,634 次查看
rubenS
Hi, I recently bought the KIT-HGDRONEK66 and I wanted to build it following the gitbook. In the gitbook they use BLDC brushless motors 2212 920 kV but in my package there are flycat i-rotor 5010-750kv.
I couldn't find any website where these motors are in this kit.
Did I get the wrong motors or do these also work? The packing list says that I've got the right motors.
标签 (1)
1 解答
9,623 次查看
GeraldP
Lucky you! You got a kit with the new motors / bigger propellers that have better performance. We have not updated our gitbook yet. Sorry for that.
在原帖中查看解决方案
7 回复数
9,624 次查看
GeraldP
9,616 次查看
rubenS
ok thank you.
Is it necessary to wait for the gitbook or is it more or less the same?
9,605 次查看
GeraldP
Mounting and connection to ESC's is the same. Also motor spin direction is the same.
9,492 次查看
PGB123
I got the same motors but was given 4 counterclockwise threaded propeller hubs instead of the 2 counter and 2 clockwise. Was that a mistake in packaging or am I missing something?
7,952 次查看
ArianRF
Hi @PGB123 @GeraldP
I got the same motors that look all counter clock wise. Did you figure out how to make 2 of them clockwise?
Cheers,
Nader
标记 (1)
7,929 次查看
iaingalloway
The motors are now all CCW (same direction) threads. Just ensure they are tightened well so they don't unscrew.
7,922 次查看
ArianRF
Thanks Iain.
I am putting your comments from a different thread here for others  who have the same questions.
"They SPIN CW and CCW, but the screw thread is all in one direction.
The rotation direction is controlled CW/CCW by swapping any two of the three wires."
Cheers,
Nader
