start up with external oscillator
1,993 次查看
matthiasuhlmann
hi all,
is there a code example how to configure occs if external Crystal oscillator is used?
标签 (1)
2 回复数
1,847 次查看
xiangjun_rong
can you tell me the part number of DSC you are using? anyway, I suggest you use PE to generate the code to use external crystal or clock source, you can select the external crystal in cpu beans.
Hope it can help you
XiangJun rong
1,847 次查看
matthiasuhlmann
Hi XiangJun rong,
I do not use Processor Expert. Would this generate a useful example?
I will try to generate example....
Thank you
Matthias
