Hello all,
I need to generate the quadrature pulse (each with 90degree displacement) like the motor encoder signals. How to generate this with eFlex PWM in MC56F8247 microcontroller. What configuration should I made for this..??
I am using codeWarrior v10.6
Can anyone help me out for solving this.
Thanks in advance.
Solved! Go to Solution.
As you know that the eFlexPWM module supports phase shift feature, so it i okay to generate the phase shift signals to simulate the PH_A and PH_B signal with PWM output signals.
I attach the example based on MC56F84789, pls refer to it.
XiangJun Rong
Thanks for your response,
I will check the code.
