PTN5150AHXMP IBIS model
Krithikka
I am Krithikka Jayamurthi and I need IBIS model file to perform Signal Integrity simulation.
TomasVaverka
Hi Krithikka,
No IBIS simulation model has been created for this device or its family parts.
The CC lines on a USB Type-C interface operate at relatively low signal speeds (USB PD BMC signaling at 300 kbps), which means they are generally not subject to the high-frequency signal integrity concerns that typically drive the need for IBIS models. Standard I²C-level or low-speed I/O characterization from the datasheet (electrical specifications: VOL/VOH, IOL/IOH, rise/fall times, capacitance) is typically sufficient to evaluate signal quality on the CC pins.
If your signal integrity concern is specifically related to the USB data path (USB 2.0 D+/D−), please note that the PTN5150AHXMP itself does not route or buffer the USB data lines - it is purely a CC logic controller. The USB data signals bypass the device entirely and are handled directly at the connector and receptacle.
BRs, Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-2412886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPTN5150AHXMP%20IBIS%20model%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20Krithikka%20Jayamurthi%20and%20I%20need%20IBIS%20model%20file%20to%20perform%20Signal%20Integrity%20simulation.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2412940%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PTN5150AHXMP%20IBIS%20model%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412940%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%3EKrithikka%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ENo%20IBIS%20simulation%20model%20has%20been%20created%20for%20this%20device%20or%20its%20family%20parts.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThe%20CC%20lines%20on%20a%20USB%20Type-C%20interface%20operate%20at%20relatively%20low%20signal%20speeds%20(USB%20PD%20BMC%20signaling%20at%20300%20kbps)%2C%20which%20means%20they%20are%20generally%20not%20subject%20to%20the%20high-frequency%20signal%20integrity%20concerns%20that%20typically%20drive%20the%20need%20for%20IBIS%20models.%20Standard%20I%C2%B2C-level%20or%20low-speed%20I%2FO%20characterization%20from%20the%20datasheet%20(electrical%20specifications%3A%20VOL%2FVOH%2C%20IOL%2FIOH%2C%20rise%2Ffall%20times%2C%20capacitance)%20is%20typically%20sufficient%20to%20evaluate%20signal%20quality%20on%20the%20CC%20pins.%3C%2FP%3E%0A%3CP%3EIf%20your%20signal%20integrity%20concern%20is%20specifically%20related%20to%20the%20USB%20data%20path%20(USB%202.0%20D%2B%2FD%E2%88%92)%2C%20please%20note%20that%20the%20PTN5150AHXMP%20itself%20does%20not%20route%20or%20buffer%20the%20USB%20data%20lines%20-%20it%20is%20purely%20a%20CC%20logic%20controller.%20The%20USB%20data%20signals%20bypass%20the%20device%20entirely%20and%20are%20handled%20directly%20at%20the%20connector%20and%20receptacle.%3C%2FP%3E%0A%3CP%3EBRs%2C%20Tomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
