If TDA8954J supply ok, clock signal ok?
3,088 次查看
zw_wuxv
Debug the module of TDA8954J, no clock signal(internal clock) , no output.
+/-41VDC supply.
2,961 次查看
guoweisun
Please update your schematic with attached application note if any difference!
By the way this device had already EOL no recommend for new design or project.
2,961 次查看
zw_wuxv
Hi G.w. Sun:
The trouble is still about the TDA8954J, Boss had choosen the IC.So we must finish the project.
There are 4 questions:
1)the led2 flickers when it has a 4OHM load(no signal input);
2)when output has a load(4ohm),the output wave is not so clear. the filter's parameters need to change?
3)What's your suggestions about the GND layout?
4)the crosstalk is big.
Can we contact with email?
