Codewarrior building error for MC56F80748 project
4,655件の閲覧回数
jimmyli
Contributor V
Hi, I try to build a simple project with FreeMaster tool by Codewarrior v11.2, but 17 errors occur. Attachments are build log, error log and source project. Hope you can help me to check and fix it. Thanks very much.
タグ(1)
2 返答(返信)
4,642件の閲覧回数
xiangjun_rong
I attach the doc which describes the steps to load the SDK example, pls refer to it.
I tried to load the "fmstr_example_uart" project and compile it, no problem
Hope it can help you
XiangJun Rong
4,637件の閲覧回数
jimmyli
Contributor V
Hi Xiangjun,
      Thanks very much.
      I will try again.
      BTW, attachment is the steps to set up project by another way, but failed.  --I need freemaster tool in project.
      Maybe something wrong in my computer, hope you can verify again.
