CAN Bus recessive differential output voltage
yuanpeng_gao
HI ALL
I design a product and can transceiver i used TJA1145T,now i test can bus in normal  mode(2 node),it working and communication  correctly,but when i test bus voltage ,i find recessive differential voltage was more than 50mV,  Max about 100mV, how reduce the recessive differential voltage within 50mv ?
