AN5014, An error is shown as "Object doesn't support property or method 'IsCommPortOpen'"
3,030件の閲覧回数
larryyang
The test environment is Win7 + IE11.
Open 'MCAT_PMSM_FOC_56F82xxx.pmp', first of all, the serial port is connected. If switch to 'Motor Identif' tab, an error is shown as below.
I try to install IE9 and IE10, it seems no effect. do you know how to solve the issue? thanks!
3 返答(返信)
2,822件の閲覧回数
johnlwinters
This sounds like you need to configure the com port on the settings for pcmaster. Using a real com port?
John L. Winters
Senior Applications Engineer
AMR/EU MCU & MPU AE Group
Freescale Inc.
2100 Elliot Road
This email and any associated attachments have been classified as:
Freescale Confidential and Proprietary
2,822件の閲覧回数
larryyang
Hi John,
I have configured the comm port on the FreeMASTER, and the com connection was OK. I used virtual com port by Open SDA.
Whether the issue associated with .Net Framework version?
2,822件の閲覧回数
johnlwinters
I would seek support from Microsoft and the vendor of your "serial port".
John L. Winters
Freescale Inc.
2100 Elliot Road
