Tools & Enablement: Safety by Software (SBSW)
Safety by Software (SBSW) is a new way of achieving ASIL-D with high-level measures, supported by NXP S32X hardware. The SBSW hardware module together with SBSW firmware enables to check the user application flow, compare results of main and redundant algorithms and detect faulty behavior with high degree of independence. This session makes you familiar with SBSW usage, configuration, tools, etc.
%3CLINGO-SUB%20id%3D%22lingo-sub-1122473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETools%20%26amp%3B%20Enablement%3A%20Safety%20by%20Software%20(SBSW)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESafety%20by%20Software%20(SBSW)%20is%20a%20new%20way%20of%20achieving%20ASIL-D%20with%20high-level%20measures%2C%20supported%20by%20NXP%20S32X%20hardware.%20The%20SBSW%20hardware%20module%20together%20with%20SBSW%20firmware%20enables%20to%20check%20the%20user%20application%20flow%2C%20compare%20results%20of%20main%20and%20redundant%20algorithms%20and%20detect%20faulty%20behavior%20with%20high%20degree%20of%20independence.%20This%20session%20makes%20you%20familiar%20with%20SBSW%20usage%2C%20configuration%2C%20tools%2C%20etc.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1122473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESafety%20by%20Software%20(SBSW)%20is%20a%20new%20way%20of%20achieving%20ASIL-D%20with%20high-level%20measures%2C%20supported%20by%20NXP%20S32X%20hardware.%20The%20SBSW%20hardware%20module%20together%20with%20SBSW%20firmware%20enables%20to%20check%20the%20user%20application%20flow%2C%20compare%20results%20of%20main%20and%20redundant%20algorithms%20and%20detect%20faulty%20behavior%20with%20high%20degree%20of%20independence.%20This%20session%20makes%20you%20familiar%20with%20SBSW%20usage%2C%20configuration%2C%20tools%2C%20etc.%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1122473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EArm%C2%AE%20Processors%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ESoftware%20%26amp%3B%20Tools%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎06-18-2019 07:47 AM
Updated by:
