TQ-Systems: How to Speed Up and Optimize Your Design with Modular Approach
To use the processor in an integrated design is one way. To use an embedded module is another way and will speed up the design, reduce the design risk and lower the design cost. What limitations and restrictions are there, if any, if you use an embedded module? A market overview and guideline to select your embedded module.
%3CLINGO-SUB%20id%3D%22lingo-sub-1099784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETQ-Systems%3A%20How%20to%20Speed%20Up%20and%20Optimize%20Your%20Design%20with%20Modular%20Approach%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ETo%20use%20the%20processor%20in%20an%20integrated%20design%20is%20one%20way.%20To%20use%20an%20embedded%20module%20is%20another%20way%20and%20will%20speed%20up%20the%20design%2C%20reduce%20the%20design%20risk%20and%20lower%20the%20design%20cost.%20What%20limitations%20and%20restrictions%20are%20there%2C%20if%20any%2C%20if%20you%20use%20an%20embedded%20module%3F%20A%20market%20overview%20and%20guideline%20to%20select%20your%20embedded%20module.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1099784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ETo%20use%20the%20processor%20in%20an%20integrated%20design%20is%20one%20way.%20To%20use%20an%20embedded%20module%20is%20another%20way%20and%20will%20speed%20up%20the%20design%2C%20reduce%20the%20design%20risk%20and%20lower%20the%20design%20cost.%20What%20limitations%20and%20restrictions%20are%20there%2C%20if%20any%2C%20if%20you%20use%20an%20embedded%20module%3F%20A%20market%20overview%20and%20guideline%20to%20select%20your%20embedded%20module.%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎09-26-2016 06:06 PM
Updated by:
