RadarSDK for S32R Processors
Writing automotive software to process signal coming from radar frontends is not an easy job. NXP’s radarSDK helps removing complexity by providing a complete API to access hardware engines inside the SoC together with a library consisting of optimized signal processing kernels that execute on the SPT accelerator. This session introduces the audience into the programming mode of radarSDK.
%3CLINGO-SUB%20id%3D%22lingo-sub-1116424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERadarSDK%20for%20S32R%20Processors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWriting%20automotive%20software%20to%20process%20signal%20coming%20from%20radar%20frontends%20is%20not%20an%20easy%20job.%20NXP%E2%80%99s%20radarSDK%20helps%20removing%20complexity%20by%20providing%20a%20complete%20API%20to%20access%20hardware%20engines%20inside%20the%20SoC%20together%20with%20a%20library%20consisting%20of%20optimized%20signal%20processing%20kernels%20that%20execute%20on%20the%20SPT%20accelerator.%20This%20session%20introduces%20the%20audience%20into%20the%20programming%20mode%20of%20radarSDK.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1116424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWriting%20automotive%20software%20to%20process%20signal%20coming%20from%20radar%20frontends%20is%20not%20an%20easy%20job.%20NXP%E2%80%99s%20radarSDK%20helps%20removing%20complexity%20by%20providing%20a%20complete%20API%20to%20access%20hardware%20engines%20inside%20the%20SoC%20together%20with%20a%20library%20consisting%20of%20optimized%20signal%20processing%20kernels%20that%20execute%20on%20the%20SPT%20accelerator.%20This%20session%20introduces%20the%20audience%20into%20the%20programming%20mode%20of%20radarSDK.%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎06-26-2017 10:42 AM
Updated by:
